New here thought id post some photos of the gas grill i'm building..
Results 1 to 10 of 11
Thread: Building a gas grll
11-28-2010, 04:27 PM #1
- Nov 2010
- north carolina
- 8
Building a gas grll
11-28-2010, 05:56 PM #2
- Nov 2010
- north carolina
- 8
welded sides in , added shelves. thermometer,instead of adding the traditional pipes,headers etc. opted to add a small breather across the back for the smoke and aroma exit..
11-28-2010, 06:08 PM #3
- Nov 2010
- north carolina
- 8
tacked together and welded. and the top is finished.. i dont really like the thermometer placement so on the next one i'll make a change.. maybe raise to creat a bump between the top and the first bend..
11-28-2010, 11:24 PM #4
sweet looking grill when do get get pics of it grillin steaks
never thought of a gas grill only ever build a trailer bbq smokerLeblond Makino mills
HAAS CNC SL-40 lathe
American Pacemaker lathe
wells index mill
hydrotel rebuilt
syncrowave 250
diversion 165
Miller Elite Vintage USA
11-29-2010, 05:52 AM #5
- Nov 2010
- north carolina
- 8
thanks..
i will be working on the bottom this week, adding the vents for air. also building the burner and another stand, or rebuild the one that its sitting on
the goal is to have it finished by the weekend, and weather permitting paint.
The first burn will be a rack of ribs !!
the next project just happens to be a pull behind gas pig cooker. im still gather material together for it, and still choosing again not to use barrels or stacks. nothing against them though.Last edited by wickeds den; 11-29-2010 at 06:03 AM.
11-29-2010, 03:55 PM #6
- Nov 2010
- north carolina
- 8
finished the bottom today. Added the air inlets to help it breath. Also cut & bent the pipe for the burner. cleaning it up in the morn, weld it and drill the holes. alittle bit of cleanup and fire this puppy up tomorrow hopefully.
12-02-2010, 02:02 PM #7
- Nov 2010
- north carolina
- 8
the burner has been drilled and also added the feet for it to sit on the bottom of the grill. fired it it up and as u can see it held 450 temp for 20 mins...
open the top and turned it down and it held 350 for the same amount of time.
the flames burned blue as well no orange tips.
12-02-2010, 02:07 PM #8
- Nov 2010
- north carolina
- 8
well here's the temp photos
12-02-2010, 06:42 PM #9
very nice looking grill.......whats for dinner?
miller 225 bobcat
miller aead200le (with miller hf tig trailer mounted)
mm175, mm211, TA181i
mm252 w/30a spool gun
precision tig 225
hobart stickmate LX ac/dc
Speedglas 9100X & XX / Miller Digital Elite
hypertherm 380 & cutmaster 52
victor journeyman & super range
ridgid chop saw, kalamazoo band saw
steel max and evolution carbide saws
6 4.5" & a 20lb 9" rockwell grinders
case 580 backhoe (for what i can"t lift)
if first you don't succeed
trash the b#####d
12-02-2010, 07:13 PM #10
- Nov 2010
- north carolina
- 8
Thanks jbmprods..
the first dinner shall be a rack of ribs..
still a little ways to go though.. took a few photos of the burner close to dark...
thinking a few changes need to be made..
build a new burner so the gas comes from the center. then drill the ends so the whole burner is alive.. makes it easier to light from one location instead of having to light it twice..
