Foot pedal or hand control on the torch, which is most popular with the pro tig welders?
Results 1 to 10 of 14
Thread: Tig amperage control
Hybrid View
12-31-2007, 05:32 AM #1
- Mar 2007
- 2
12-31-2007, 05:45 AM #2
- Dec 2007
- alabama
- 722
i would say foot.more versitile.less problematic.
XMT 350 cc/cv
XMT 350 vs
TRAILBLAZER 302
MILLER DVI
PASSPORT PLUS
DYNASTY 200 DX
MAXSTAR 150 STL
HOBART CHAMP
HF-251 BOX
12-RC SUITCASES
12-VS SUITCASE
12-31-2007, 10:23 AM #3
Foot provides the most control. I have been using foot for 6 years. I have used the miller N-S finger control for some tasks that require it, but haven't liked it. I have been looking for a better design. I think the one that might work best for me would be a switch on-lock-off, but miller only sells a momentary on and I haven't seen any 3rd party like this for the millers. I wonder if something like that would damage the machine..?
As a side note, the reason I don't like the N-S rotary control: the starts are fine; you ramp up the amperage, but when you're done with the weld you can back off fast like a pedal so it can mess up the end of the weld a little. Also using the control limits how you can hold the torch.
I have sometimes used the pedal with my knee or simply manipulated the piece I'm welding to avoid having to use the fingertip control.Miller Maxstar 200 DX
RMLS-14 Momentary Hand Control
Miller Syncrowave 180 SD
Porter Cable 14" dry metal saw
Hitachi 4.5" grinder
http://mhayesdesign.com
12-31-2007, 03:21 PM #4
Member
- Nov 2007
- 36
foot control on finger
Most the time you can get by with just the foot control but if you have to lay under a pontoon boat or bend excessively to weld a commerial sink and anything else that is out of postion then the finger control is nice to have. It all back to what your jobs are but being in a field that requires a lot of different tasks, it is nice to have the convience of both that is why I have both in my operation. I personally use the hand held slider control all the time so that I don't get too use to just the foot control. You might get rusty by not using the finger controller if you use the foot controller all the time and when you need to switch because of a certain job, you you could have a problem for a short time. Trials of variations are good to know.
12-31-2007, 03:30 PM #5
I am frustrated by the lack of variety in finger controls for 6-pin. It seems like there could have been a standard or adapters.
01-01-2008, 08:07 PM #6
Hello tasslehawf
I was just looking in the miller book and they really don't have much of a selection for tig controls, I have a 14 pin east-west control and seem to like it very well but in years past i've used the on-off button type and like that style much better because I do alot of custom work and seem I have more movement and can get a better arc control. this is only my opinion and you need to use what works best for you. Safetydave
01-01-2008, 08:22 PM #7
This pretty much sums up how I feel as well....If I had to depend on a foot pedal to do my job it would be a joke a lot of the time. Yea you can make a foot pedal work just about anywhere but in some situations the weld quality WILL suffer because that is where you are putting your effort.
I have worked in a few factories welding pontoons and ambulance bodies and trust me is is far to fast paced for someone to use their foot pedals
On the boats we used the button...you just set max amps and bust @$$!!
On the ambulances we used the east-west style fingertip controllers...they have a faster action than the north-south and you can simply flick them off when you get used to them. The north-south is too slow...for some reason almost everyone tries them and it seems Miller tries to sell them the most...they TRULY suck IMO..they do NOT work the same.
Both (button and figertip) were a little hard to get used to at first but I will assure you there is no way in God's green earth a man with a pedal could ever keep up in a situation like that. You would simply be fired or never even hired.
They DO test you with what they use there. We have a half dozen or more factories in my area that tig weld aluminum products exclusively and only ONE uses the pedal and they DO sit all day...lucky ba$t@rd$. (my son worked there)
I like the pedal... it is just not practical to use while in the field and besides I'm getting old enuff that when I'm crammed back in a hole under something lower than my head while sitting but still can't lay down I tend to get tired way faster trying to make something work that just don't. You might do say a bead or two but after say 2-3 or more hours you'll be looking for a better way. Besides in the field it is one more cord to get tangled up...the button or fingertip control is run in the sheath.
All that said if you can sit down and weld in a shop and don't have a boss/customer pushing you to get done or have the time to stop and work thru how to position yourself perfectly then by all means get the pedal!!
BTW do a search on this and the other site and you will find this an ongoing subject that will never go away!!Last edited by FusionKing; 01-01-2008 at 08:24 PM.
Miller Bobcat 225 NT
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Miller Spoolmate 200
Miller 225 Thunderbolt
SPEEDGLAS 9100XX
12-31-2007, 04:17 PM #8
I've been TIG welding for 15 years, and there's nothing like the control a foot pedal delivers. Amperage control on the torch means less dexterity during welding and less control of heat output. I've used the torch mounted amptrack and found it only useful for tacking out of position, or when a pedal is not going to fit in a tight work space. It's all a matter of preference, I'm sure there's alot of guys here who would swear by it. That's my 2 cents!
12-31-2007, 05:04 PM #9
Member
- Oct 2007
- 34
You can even use a foot pedal while laying under something. I put one foot behind the back side of the pedal, with the pedal on it's side, then operate the pedal with the other foot. Where there's a will...........
"smokin' joints for 19 yrs."
A.A.S. Weld Tech.
AWS CWI 08011711
01-01-2008, 12:21 AM #10
with the foot control you can stop a bead and move around then start the bead right back where you were, but with my experience with the finger control if you try to add on the back of a worm bead then you will get burn marks and it will be harder to get the arc set right.
I also prefer foot over finger any day.
