Hafco a machinery supplier in Australia had a Spring sale.
During their sales they invite potential buyers to road test their products.
I have had my eye on a sheet metal roller for a while so I decided to go.
I took some 1.6mm thick ali tread plate.
The roller is rated at 1.2mm thick steel.
The ali tread plate rolled well.
I was thinking of making MX bike exhausts with the roller and from what I saw it should be able to do the job.
Ji
Results 1 to 8 of 8
Thread: Sheet Metal Roller
11-25-2010, 02:47 PM #1
Sheet Metal Roller
Grip it and Rip it
11-25-2010, 02:58 PM #2
While I was eating my free lunch I took some images of the floor stock.
JiGrip it and Rip it
11-25-2010, 04:12 PM #3
Nice. Thats almost like my Tennsmith slip roll. I got tired of all the hand cranking so i added a motor and gearbox...Bob
11-26-2010, 05:26 PM #4
Was it hard to do Bob?
Can you post some images?
11-26-2010, 05:49 PM #5
I didn't do mine the proper way but it works for me. I should of had the mtr/gb on the left side but i didn't have a lathe so i put it on the right side. The proper way would of been get a longer piece if barstock to turn down the end for the coupling for the drive. I could of done it on mine but it would of shortend the rolls some and i didn't want that. Here are some pics. I use a 3/4hp motor and a 60:1 Boston gb i got on ebay. I made my drive setup removable because i use it on 3 other machines. Why buy 4 sets of everything when you can just remove 2 or 3 bolts and change it. The handle was removed and it had a sq stub on the rolls. Then i bought a lovejoy coupling that slid over the sq and added steel shims on the sq part so the bolts from the coupling would grab and keep it from wobbling around. The last pic is my mtr/gb set turned sideways on my scrollergbonrolls.jpggbside.jpggbtag.jpgscmotor.jpg...Bob
11-26-2010, 09:32 PM #6
Nice set up Bob.
Looks like a lot of work.
Is it still easy to remove the top roller when making a complete circle?
11-27-2010, 05:50 AM #7
11-27-2010, 03:46 PM #8
I have also had my eye on one of these hole punches.
Again my test piece was some 1.6mm thick ali tread plate.
I know that is not much of a challenge but it is what I use all the time.
That is a 10mm or 3/8 hole.
I just let the handle drop and it punched the hole.
