Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Nov 2010
    Michigan
    34
    made the bed 1 foot longer for better center of gravity .
    extra tong tube for extra strength .
    Don
  2. #22
    Nov 2010
    Arkansas
    41
    The composite decking material is a good idea. I'm sure it's heavier than the alum and it doesn't look as rich but a good, cost effective alternative for certain. I build small cargo trailers that are pulled behind motorcycles and up to now have been using powder coated steel for the frame/tounge assembly. I have said for some time that I would like to change to an alum assembly, I guess I'm gonna have to get the spoolgun warmed up. I'm using a 30A off of a MM251. Are you using 1/4" or 1/8" thick stock on your trailers?
    Stephen
    Millermatic 251
    Miller Syncrowave 200
    Miller 30A Spool Gun
    Hypertherm PowerMax 30
    Etc., Etc., Etc......
    Western Arkansas Welding
  3. #23
    Nov 2010
    Michigan
    34
    Quote Originally Posted by goinssr View Post
    there is a little of both sizes of material .. the tube frame is 1/8 wall other things are 1/4
    got any pics of the trailers ??
    Don
  4. #24
    Nov 2010
    Arkansas
    41
    Here's a few pics of my little trailers....
    Stephen
    Millermatic 251
  5. #25
    Nov 2010
    Arkansas
    41
    Don...PM sent.
    Stephen
    Millermatic 251
  6. #26
    Nov 2010
    Michigan
    34
    Don...PM sent.
    Got it .. sent p/m back
    sweet little trailer .. are those well guard boxes your useing ??
    Don
  7. #27
    Nov 2010
    Arkansas
    41
    Quote Originally Posted by Alumitech View Post
    Don
    The boxes are UWS. Very high quality box, insulated lids,....
    Stephen
    Millermatic 251
  8. #28
    Nov 2009
    Amarillo,Tx
    4
    Harleys and croch rocket's have wider rear tires , so the next ones getting a diamond plate deck and locking wheel chocks .
    My thought would be to just graft a wider c-channel section to the 5" instead of plating the whole trailer. Keep the overall cost down for customer. All you would have to have as the wider channel is the rear most 12"-24" depending on wheelbase of bike.
    Regards....
  9. #29
    Nov 2010
    Michigan
    34
    I finally sold the 2 extra trailers i built .. tough sell to some that are used to cheep 700.00 trailers .. but 2 harley guys bought them .
    I feel its time to build a few more in steel .. to keep the price down , to a 900.00 buck range .
    Going to use 1.5 x 2.5 Steel tube 1/8 th wall .. 3 rail design like the first one with Aluminum rails .. aluminum diamond plate fenders .. white steel wheels .. 5/4 deck material .
    pics are of the aluminum early version .
    will post pics of the new steel unit as i go .
