Results 11 to 20 of 29
    Nov 2010
    Michigan
    34
    Quote Originally Posted by andyman View Post
    are you using 5356 filler?
    when i first start playing with my MM211 and spool gun. I bought a roll of 5356 aluminum wire and it welded like crap burnt up all my tips on the factory setting. I went back to the store to get more tips and to try some 4043 filler. The guy at the store thought it was weird the 5356 wasn't working. so we called miller and they don't recommend using anything but 4043 on the MM211. got my rolls of 4043 and seems to work great.
    yes 4043 is in the spool gun .. im finding better results with the settings and more angle with the gun ... still some soot
    Don
    3,959
    Quote Originally Posted by Alumitech View Post
    that would be my regular business
    if you care to take a peek
    www.AlumitechReproductions.com
    Don
    Those are nice radiators. I could see one in my '64 T Bolt clone project. I have a nice 4 row cross flow but alum would look nicer...Bob
    Baton Rouge, La
    47
    I have run .030" 5356 SuperGlaze with my 211 / Spoolmate 100 with no problem... Sometimes you have to turn those knobs on the front of that little blue box!
    Nov 2007
    184
    Don,
    Not to hijack your thread... but I'm looking for a source for just aluminum
    cores. Want to build my own tanks, brackets etc.
    Any online source you can suggest?
    Dave P.
    Nov 2010
    Michigan
    34
    Quote Originally Posted by FM117 View Post
    Don,
    Dave P.
    you can contact
    http://howeracing.com/ they have and sell cores
    Don
    Nov 2007
    184
    Don,
    Thanks, they're not too far from me.
    Dave
    Oct 2010
    I push only which seems to minimize the soot and also re brush each joint just prior to welding this also has reduced my sooting to almost nothing.
    Nov 2010
    Arkansas
    41
    I really like the trailer design. Nice work. Who built the axles for you? I have been using Dexter for all of my trailers but I like the individual units like you have incorporated. That type of axle would allow a lot more flexibility in design than a one piece axle.
    Stephen
    Millermatic 251
    Miller Syncrowave 200
    Miller 30A Spool Gun
    Hypertherm PowerMax 30
    Etc., Etc., Etc......
    Western Arkansas Welding
    Nov 2010
    Michigan
    34
    Quote Originally Posted by goinssr View Post
    The first trailer I did with the Axle stubs .. bought on e/bay .. nice cause you can make the trailer any width you like un like the standard full axle where the perches are set to a standard width .
    Don
    Nov 2010
    Michigan
    34
    well I have been busy trying out 2 other designs .
    HERE ARE SOME PICS
    full diamond plate deck .. expencive
    all 3 units I have added a 2nd tube under the tong for extra strength .
    Added diamond plate between the rails on the 1st unit
    simpler set up with composite decking .
    Don
