Results 1 to 7 of 7
    Aug 2010
    Rhode Island
    26
    Default Leaf loader swing hitch
    My freind owns a landscaping company and with leaf season coming he wanted to build a swinging hitch for his leaf loader to save on time dumping leafs. Its a little overkill but it gets the job done.
    May 2008
    Troy, MI
    377
    Nice job. I especially like the roll cage to protect the leaf blower.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Apr 2006
    TAXACHUSSETTS
    1,504
    I have done similar to a few units i mount the flanges to the d-side corner post of the body and swing the blower unit around to the side of the dump and use a chain hook latch with the thumb slide to attach it to a link i weld to the side to prevent swing back when the body is raised.This time of yr i see a few impellar housing and discharge chutes needing patchs i just did 2 last week for a couple of local leaf chasers around my area.BTW job on that looks good.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Aug 2010
    Rhode Island
    26
    thats next, his impeller housing is getting some holes in it.
    1,919
    Is there something to hold it in the open position?
    2,957
    Why did you Block out the Business name?
    ( You left the tag Visible )
    Aug 2010
    Rhode Island
    26
    I guess i just didnt want him getting any random phone calls, some thing that holds the impeller on? or the housing? its just bolted together
