Page 1 of 6 123456 LastLast
Results 1 to 10 of 58
    Utah
    162
    Default Mid-Engine Sandrail Project
    Well after about 15 years of wanting to build a sandrail I finally pulled the trigger and commenced my build. I started with one that I purchased that was damaged/wrecked but had some nice parts on it. I cut about 90% of the original car away and fabricated basically an entire new chassis from 1.5" DOM tubing. I am making the chassis wide enough to be comfortable whereas the original was built for a very small individual and was not even comfortable it I were to have just repaired the damage.
    I was going to widen the bench seat that was in the car when I widened the chassis, however, after meeting a gentleman at the dunes a couple of weeks ago and sitting in his car with suspension seats that totally changed my mind. Suspension style seats looked like the way to go.
    I have built several street rods and muscle cars as well as a few custom ATV chassis and felt as though I was ready to tackle a larger all tube chassis. This is my first sandrail chassis and hopefully there will be more to follow. I am really enjoying this build, more so than many of my projects as of the last few years. Thanks for looking, Mike.
    This picture is of the majority of the original car cut away and the new chassis coming together while sitting on the frame table that I had just built.
    This picture is of one of the joints where I joined the new tubing to the original. As per NHRA specs the tube must be at least one and one half the diameter of the tube in either direction of the seam. Must have rosette welds on either side of the seam approx. 1/2 the diameter of the tube from the seam and the inner sleeve must be at least the same wall thickness as the outer tube. NHRA also recommends leaving about a 1/8 inch gap between the two tubes so when welding both tubes and the inner sleeve are all fused together properly.
    This is a view of the rear with the new outer upper and lower main rails bent, fishmouthed and tacked into place.
    This is a picture of one of the welds on the rear crossbar.
    Utah
    162
    This picture is of the suspension seats that finally showed up.
    This is a picture of the some of the seat tabs. All of the little tabs are what takes time. The large tube bending, fishmouthing and tacking makes it look like I am really kicking butt, however, when I start fabricating the little tabs I feel as though I am going in slow motion. To fabricate these four brackets it took about 15-20 minutes, which may not seem like a long time but there will be a lot of small brackets and tabs on this car. This is also what makes or breaks the entire project. These little brackets get overlooked when done properly but jump out and look like a sore thumb if done half-assed.
    This is a picture of one of the welds for the fuel tank mounting bracket.
    This is a picture of the rear upper crossbar that resides just behind the seats. It will be the attachment point for the 5-point/5-way Crow harnesses as well as the upper radiator mounting location.
    Utah
    162
    This is a picture of the 'B' pillar bent, fishmouthed and tacked into position.
    This is pic of the 'A' pillar along with the small connectors between the 'A' and 'B' pillars.
    This is a side view of the 'A' and 'B' pillars with a rear paddle thrown into the picture for perspective.
    Utah
    162
    This is picture of the antenna bung that I am machining in the lathe.
    This is the two pieces threaded together to test fitment.
    This is the two parts seperated for visual.
    Utah
    162
    This is a picture of the above machined antenna bung welded to the 'B' pillar.
    This picture is of the 'C' pillar tacked into place. The original car only had a four point roll cage but I feel a little better with a 6-point cage.
    This is a picture of the two tabs that will be welded to the upper crossbar and allow me an attachment point for the upper radiator mounting brackets.
    Dec 2005
    East coast
    206
    Sweet, been wanting to do one myself, time dictates otherwise..
    Powerplant?
    Two Dynasty 350's with Wireless pedals
    Profax 250 weld positioner
    Bridgeport mill
    Logan Turret lathe
    RMD tubing bender
    Enco vertical saw
    Baileigh Auto cold saw
    IR 80 Gal dual stage compressor
    Misc Fab equipment
    Utah
    162
    Quote Originally Posted by Checkered Flag View Post
    Powerplant?
    Thanks, I will be running a turboed Mazda 13B (dynoed at 365) plus a 60hp shot of NOS. Hopefully in a completed chassis that is close to 900 lbs. Mike.
    Utah
    162
    Well I didn't get much time last night but was able to get a couple of small items taken care of.
    The first picture is of the shifter tack welded into place.
    This next two pictures of of the upper radiator mounts that I fabricated and tacked the upper portion to the crossbar and fabbed the other part to bolt between the upper mount and the top of the radiator.
    This last picture is of the fuel tank mount which postions the fuel tank between the radiator and the seat but has to be elevated enough off of the lower rails to allow the shifter linkage to pass underneathe.
    Mar 2009
    Corona, CA
    213
    I know for a fact that motor will catch the eyes of the LS1/v8 sand rail crowd. First, they'll want to know what it is...then when you tell them its a 1.3L, they'll crap their pants. Nothing turns heads like the sound of a pissed off weedwacker.
    What are you running for a transmission? VW Bus swingarm?
    1,880
    Very nice work! Your a lucky man to have the time to build something like that.
