Results 1 to 10 of 12
    May 2006
    180
    Default XMT 350 CC/CV & Optima Pulse vs XMT 350 MPa
    Which is better, a XMT 350 CC/CV with an Optima Pulse control or a XMT 350 MPa? I ask this because I have the XMT 350 CC/CV and am considering combining it with a possible Optima purchase for use with my 30A Spoolmatic for use on thin (17 or 18 ga.) AL . Is the MPa a whole bunch better, or just the same?
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    Miller 30-A Spoolmatic w/WC-24
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    O/A Rig, Enco 4x6 bandsaw, etc.
    May 2006
    180
    Come on, doesn't anyone (even a miller expert) have experience with the 350 MPa?
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    I use a XMT 350 MPa with a 30A Spoolmatic on aluminum daily at work, mostly 1/8" Alum and thicker. It's a great machine, the thinnest I have welded is 14 ga Alum. (If I remember correctly)Should have used a spool of smaller filler but didn't have any, still seemed to work well though. I have no experience with the 350 CC/CV so I can't make a direct comparison, sorry.
    at home:
    2007 302 Trailblazer with the Robin FOR SALE
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    May 2006
    180
    Quote Originally Posted by c wagner View Post
    Thanks very much for your reply. Have you ever used the 30A with a Miller Optima pulser connected to any power source? If so how did it compare with the pulser built into the MPa? I'm trying to decide whether to splurge on an Optima. I might get an Optima if it's pulse abilities are equal to or better than the MPa's.
    Nov 2007
    1,270
    No sorry I have never used the Optima pulse control, hopefully someone else can help you out more.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    May 2006
    180
    Thanks c wagner for your response. Anyone out there with experience on the XMT 350 MPa/Spoolmatic as well as with the Optima pulser/Spoolmatic?
    Nov 2007
    231
    You should contact the miller mig department directly. Ask them the differences between the mpa and optima pulsing programs. I'd betcha the mpa wins. Then if you don't believe them, contact your distributor and have them set it up and run it yourself.
    -dseman
    Nov 2006
    Appleton
    8
    Default Optima VS. MPa
    Your welding application is rather demanding, thin aluminum material. I would pick the XMT 350 MPa over the Optima. The MPa has a very stable arc at short arc lenghts, which is what you need for thin Aluminum.
    If you going to just do a little project and never weld aluminum again, then go for the Optima and save some money. If your doing a big project and aluminum is becoming a material you weld frequently, go for the MPa, you will be much happier.
    Ken
    Miller's XMT Product Manager
    Nov 2007
    231
    Quote Originally Posted by PMKen View Post
    Ken
    Ken,
    How about comparing the MPa to the MM 350P on a wide range of aluminum from gage to plate? If we disregard the push/pull offering that the MM 350P has and used both with spoolguns, are they similar or is there a clear winner--and why?
    thanks,
    -dseman
    May 2006
    180
    Ken
    Thanks Ken for the insider advice. That's just the info I was looking for; question answered.
