I am looking at building a set of gambles for hanging deer. Any sugestions? thanks![]()
Thread: Gambles, any sugestions???
11-16-2010, 07:18 AM #1
- Feb 2010
- 11
11-16-2010, 08:51 AM #2
- Feb 2007
- Near Dallas, TX
- 214
Don't make it too wide. I made this mistake once and had a dead hog laying on the ground while I was in the shop cutting and welding
I use 1/2 rod and 1" black pipe (mostly because that's what I had laying around). Cut your rod to length for the end hooks. Hold them against the bench grinder and spin the rod to put a point on the end, THEN bend them in a hook shape. It's much easier to put the point on it when the rod is still straight. For the hanger in the middle I just U-bend another piece of 1/2 rod. Make sure this it big enough for a chain hook to pass through. Alternatively you could use a piece of 1/4 place with a hole and slot that will grab a chain between the links.
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
11-16-2010, 06:19 PM #3
I hope they had their day in court. What did they do. Steal some corn?
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
11-17-2010, 02:21 PM #4
- Apr 2010
- 21
11-17-2010, 03:14 PM #5
- Feb 2010
- 11
11-17-2010, 03:15 PM #6
- Feb 2010
- 11
thanks guys it was greatly appreciated, helped me out alot
11-17-2010, 06:11 PM #7
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
11-17-2010, 06:42 PM #8
- Feb 2010
- 11
11-26-2010, 01:44 PM #9
Here is a link to an adjustable Gambrel. It seems pretty easy to clone.
http://www.texashunterproducts.com/ortgaga.html
