Results 1 to 4 of 4
    Sep 2006
    309
    Default Drilling depth for posts in concrete
    I can't remember where or when I heard it. But I've always used one and one half times the material thickness for the depth of a hole for pipe or tubing.
    So a one and a half schedule forty pipe would be approximately three inches. (1 7/8" X 1.5 would be 2 3/4")
    I don't believe I pulled this out of the air. I'm comfortable with saying it's something an engineer or someone close to one told me.
    Am I wrong?
    Mar 2006
    northwest Pa
    79
    I belive you are correct, but remember that's minimum.
    Sep 2006
    309
    Quote Originally Posted by Ray C. View Post
    I'm glad you mentioned that. It is the minimum.
    Mar 2010
    DFW TEXAS
    52
    Default A little diffrent but same princable.
    I always use 1.5 of the outer dimension for my depth. My experience comes from some college and working as a rigger for some time. My reasoning is this, if you are bolting something up and you only screw in the bolt 1/2 of the OD of the bolt you are not getting max tensile strength of the bolt you must go the OD+1 turn to get max tensile strength out of the bolt. I always shoot for the max, you wouldn’t help pin a weld would you? No you want a full pin. But this is max not min so you make the call on what you need.
