Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 68
  1. #51
    Austin, TX
    621
    On my first welding table, we used 1/4" plate for the top. I believe the mistake I made was welding to top onto the base. What happened was that the edges got pulled down by the welds. In retrospect, I would have bolted the top on instead.
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
  2. #52
    Jul 2007
    Southern NH
    233
    the best advice i have for a welding table is "dont weld the top to the frame." if you feel it absolutely must be secured then bolt it! but honestly, where do you think the top is going to go? i mean most tops are 1/4" plate and weigh at least 150 pounds-- it ain't going any where. my top weighs 400 pounds and i can barely slide it across the table-- there is absolutely no need to secure it.
    by keeping the top separate from the table, the table can be broken down into lighter pieces in case you ever need to move to a new location. the other obvious advantage is that the top doesn't warp from the welds.
    miller dynasty 350
    miller spectrum 1000
  3. #53
    4,494
    I weld the top on it can become part of the structural integrity of the table but no need to weld the crap out of it, 3 or stitches along the length of the angle, a bit on each corner and in the middle of the angles on the ends. I don't even fully weld the corners of the frame work, just where I need it.
  4. #54
    Mar 2008
    Baltimore, Maryland
    315
    The boom is used on occasion to drop leads and cords down on projects to keep the stuff off of the floor.
    Great Idea!
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
  5. #55
    Feb 2008
    Milwaukee WI
    57
    Awesome thread and great ideas!
    once I get my Jap truck frame welded up, i'll be building a table!
    MM
    Millermatic 210
  6. #56
    Aug 2008
    BC Canada
    6
    Quote Originally Posted by EdZep View Post
    One problem I've noted is that the inside tubing seams will interfere with sliding of an otherwise properly sized inner tube. How do people remove those seams? Or, maybe I'd have to use round tubing, as the seams are off near an edge.
    You can purchase square tubing with a clean interior. Towing hitch shops often use it for hitch extensions. It is very expensive.
    I put a large electrical box well under the table with multiple plugs and a short tail for an extension cord. Plug boxes tend to collect grinding dust unless well underneath the bench.
  7. #57
    Sep 2008
    s/e michigan
    37
    The table looks pretty practical for someone like me who doesn't do "heavy stuff".
    >> does anyone have some photo of some welding tables getting ready to build one .
    Brian, here's a pic of my nearly done table from the Miller plans. My first welding project, with a new MM180. I learned too late that the edges of the 3/8 plate could droop a little, with voltage high enough to get good penetration. Glad I used scrapyard plate. I think I should have welded the top on along the inside edge of the frame, rather than the more accessible outside edge. Or, maybe I should have turned the whole thing over, rather than sitting on my butt and doing overhead welds.
    >> You put shims inside the tube to offset the seam.
    Fishy Jim, thanks. Yeah, and I guess I should have made sure all the seams were turned the same way, so shims could be applied the same everywhere needed.
  8. #58
    Sep 2008
    Delta B.C.
    33
    Default My Table
    Here is my home table.
    It was my first project afew years back.
    It fit's in my work-mate.
    This shows the wind/flash guard.
  9. #59
    Fallbrook CA
    20
    I have 2 small vices each mounted to a seperate 12" x 12" x 1/4" plate. You need to counterbore the bottom mounting holes in the plates so they lay flush on your welding table. They are not bolted or clamped to the table they just slide around to wherever you need them. mighty handy for holding those small and awkward pieces when you are tigging them.
    Harold
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
  10. #60
    Nov 2005
    117
    Default Welding Table Accessories
    I have 2 tables in my own shop and one where I spend 8 to 10 hrs each day day job and I made the frame out of square tubing leaving the longer ones open on the ends "not mitered '' or boxed in then I put a smaller tube in each one of them I slide them out as I need to hang lead stinger C CLAMPS OR for table extensions my tool boxes are opossite table so when I trun around I can get hood grinding shield from hooks at top of tool box about 6 foot high 1 table is slanted for prints sketches or writing the other is flat also tables have a shelf for small parts or drops Hope it helps
