Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 68
  1. #31
    Mpls, MN
    1,790
    Quote Originally Posted by Jetmekdc-10 View Post
    For the love of god man, look at all the wasted space under that lovely table!
    Seriously, under fab-table space is usually completely under utilized. You're giving up on so much cubic footage it's sad.
    If you don't need the cross bracing for the legs (like the above bench), you could make a cart that fits under there and rolls out for easy access to all your stuff. It would be easier to build than making a drawer that served the same function.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
  2. #32
    Austin, TX
    621
    Well I got my new welder today so it's time to start on a multi-function garage size table (10 x 4 won't cut it for home use).
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
  3. #33
    Nov 2007
    West Georgia
    103
    Default excellent details
    Rob G, thank you for all those great ideas and detail shots. I made my take on a torch holder clamp today, and quite like it.
  4. #34
    Wartburg,Tn
    575
    Thanks Rob G ,
    I like the mig gun holder! I always get my jacket /shirt caught on mine , may have to build one
    Thanks,chris
    Inferno Forge
    Chris
  5. #35
    Southern, AZ.
    15
    Default re
    Here is my Mig gun holder. I just have holders under the table so I can move it around.
    Don D.
    Miller Passport
    Miller spectum 375 X-Treme Plasma
    Victor torches
    to many 4 1/2 grinders (not)
    25 x 40 shop (dog house)
  6. #36
    Southern, AZ.
    15
    Default re
    Here is some for my Oxy set. It slides in and out when in use or not.
    Don D.
    Miller Passport
    Victor torches
  7. #37
    Southern, AZ.
    15
    Default re
    Here is my ajustable light when I need one. I was messing around with a C clamp and Brazed it to a plate and welded 1" tubing to that and inserted 3/4" tubing with a small shop light in it. I welded a nut to the 1" tube and a 16 penny nail to the bolt to lock it at any place.... It will be over my head and shining down on the weld.
    Don D.
    Miller Passport
    Victor torches
  8. #38
    Southern, AZ.
    15
    Default re
    I also took my grinder and cut notches in the corners of the big table for a cheep ruler guide. Longer notches for full inch and half notches for 1/2 inchs...
    five or more tapes laying around and you can not find one when you need one!
    Don D.
    Miller Passport
    Victor torches
  9. #39
    Southern, AZ.
    15
    Default re
    My small table I started with and now use it for cutting and clean up. I use the mounted grinder to cut and clean edges for welding and the swamp cooler motor for well you know... I saw that on a forum years ago with the grinder from a guy named Ernie L. ???????? I took the grinder that it was built for off because it was one of the H/F grinders and it would walk all over the floor if I was not holding it down and to noisy.... The De Walt is much quiter and more amps..
    Don D.
    Miller Passport
    Victor torches
  10. #40
    Default modular table
    One of my first projects was to build a table out of some scrap angle and plate I picked up at one of those "by the lb" places. It's about 60" wide x 38" deep with a .25" top. Now I need a table to catch the slag from cutting with the torch, and I need to mount a post-dolly and bead roller, but don't have any space in the garage. My solution was to build a "work-station" for metal-mooshing. I welded in two 3" square horizontal tubes under my welding table. In these slide 2.75" square tubes with holes to lock into different positions in the outer square tube. These smaller horizontal square tubes are welded to vertical square tubes, which act as receivers for different tools. In the pic I've got a post-dolly stuck in the end. I can remove the receivers when not in use and store them under the table.
    I also wanted to make a cutting table for my torch, so I welded angle on to the horizontal 3" square tubes to act as a shelf for a frame I made out of angle. I also added some angle above the shelf to keep the sliding frame from tipping when extended. I filled the frame with angle, and now I have a cutting table I can slide away under my welding table when I don't need it. Ian
