    May 2008
    Troy, MI
    273
    Default Gun Holder for Hunting
    A friend at work asked me to fabricate a gun holder based on his sketch on the back of an envelope. I'm not a hunter so I can't tell if it is a good design or a bad one. The idea is to push the stake into the ground and the fork, which will be covered with rubber, holds the barrel of the gun.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    3,653
    Looks like it will work. Is that 1/2" sq tube?...Bob
    Delmont, PA
    291
    Hey Don,
    Here's a couple pics of some of the rests I make. Pics #6 & #8 are the adjustable field rests with 2 position heights for prone & sitting. I also make an easy base to add to it to use it on a bench. Maybe these pics will give any of the shooters/hunters on the forum some ideas.
    Denny
    * Complete welding, machine, & fab shop *
    * Mobile unit *
    * Finally retired *
    * A man's word is his honor..... without honor, there is nothing. *
    * Words are like bullets..... once they leave your muzzle, you cannot get them back. *
    * I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
    * Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
    May 2008
    Troy, MI
    273
    Yes, it is 1/2" square tubing with a 1/16" wall. My friend wanted to keep it light. I cut a notch in the chisel end and welded it up to make the point.
    Quote Originally Posted by yorkiepap View Post
    Hey Don,
    Denny
    I am going to show pictures of your rests to my friend. It may give him other ideas. Thanks for taking the time to post the pictures.
    Don
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Aug 2010
    Texas
    Thumbs up
    Quote Originally Posted by Don52 View Post
    Don
    Nice rests. The first thing I thought of you answered in the bold text. I think if you'll be stationary and have the room that setup will work great. If you're going to be mobile the setup might be a handful. But it'll all really be in how you're using it.
    Either way, nice job.
    May 2008
    Troy, MI
    273
    Quote Originally Posted by Monica View Post
    I see that this is your first post. Welcome to the forum. I hope that you enjoy it.
    My friend said that he will hike in to his hunting site and then set up and stay there for a period of time and enjoy the surroundings and hunt if anything came along. He has always enjoyed the outdoors and he likes camping. This year his sister got re-married so it will also be a chance to spend some time with his new brother in law.
    Don
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Delmont, PA
    291
    Hey Don,
    I went back thru my project photo file & found a couple more that will provide better detail. If you look at pic #6, you can see a small tab to the left of the upper support. That is a belt clip I made & welded on so I can carry it easily. These additonal pics show how the base is made & the belt clip use on my bro's belt.
    Denny
    Addendum: I forgot to mention the jig I designed & built to make these. I'll dig up those pics & post them here on this thread.
    * Mobile unit *
    * Finally retired *
    May 2008
    Troy, MI
    273
    Hey Don,
    Denny
    I had guessed that the base was a separate part but the last picture clarified this. From your new pictures, I finally figured out that the thumb screw is to clamp the telescopic leg at different heights.
    I hope that my selection of 1/2" x 1/16" wall square tubing will be rigid and strong enough for my the rifle rest for my friend.
    Thanks,
    Don
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Jun 2010
    Howell, MI
    14
    I think you did a fine job. I am a paraplegic in a wheelchair, so I needed the same sort of device since I lack stomach muscles. (no movement from nipples down). I really cant shoulder the gun right out in front of me, because I will just fall over! I CAN shoulder it, but only to the side, not directly in front of me. I bought one from ****'s sporting goods that is telescoping. As long as he gave you the right height, or as long as it can be pushed into the ground farther to GET the right height, it will work great! Nice work!
    Rudy
    T-4 Paraplegic, Runnin' the Pedal With my elbow, now trying to get used to a momentary switch.......
    Journeyman Millwright, Local 1102, Detroit, Michigan (Disabled)
    Syncrowave 200
    Coolmate 1
