Results 1 to 8 of 8
Thread: welding table
    Nov 2010
    25
    Default welding table
    looking into building a weld table. i will be using for an assortment of things including lots of bending with a vise. any ideas would be great. i get material at cost, but i think 1/2" top is over kill for what ill be doing.
    May 2008
    Austin Tx.
    101
    Smile go for the best.
    If you get materials at cost, go for the 1/2".
    You clean a welding table off with a grinding disk as a rule.
    Or at least, I do.
    Dec 2008
    Arizona
    812
    Default Size Matters
    Get the biggest, thickest plate you can afford (and move). A 4' x 8' x 1/2" plate will weigh in at 652.8 LBS. My wife got me a 3/8" plate as a gift and asked the steel supplier to throw it in the back of her Geo Metro! Ignorance is not bliss!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Nov 2010
    25
    Quote Originally Posted by nocheepgas View Post
    lol...geo metro...lol even at cost 1/2" may be a lil $$$. i will see what the price is from my ex boss. 4X8' would be nice, but i am thinking i may only need a 4X4' table. i have a 2 car garage and its a lil tight. tomm ill get some quotes on table tops and sizes and post them on here. thanks for all your replies.....3/8"+ geo metro = nightmare....lol
    Apr 2008
    dallas,tx
    207
    I went 1/2" on mine and in retrospect, i'd have gone 3/4" and have it ground flat but that was quite expensive.
    Sure you can go thinner and then spend the money you saved on the top on support structure for the thinner table. Depending on the material you are going to be bending, you may want the added mass of a thicker table to keep it from walking as you bend something in the vise. Also if your work requires the frequent use of a 5 or more # persuader (hammer/sledge) you may want to go with the thicker top
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plenty
    Dec 2009
    Custer Park, Illinois
    92
    Can take a look here it might have a couple ideas you can use.
    http://www.youtube.com/watch?v=NgA0i1AYh30
    The frame is gonna have to be heavy and stout to do any bending or you'll be chasing it around the floor.
    The heavier the top the better but also more $$$. I fabbed my top from what I had on hand. Definitely not ideal but works good for most of what I do.
    Hope it helps some. Al
    Miller Dialarc 250 HF
    Lincoln Classic 300D
    AutoCAD 2010...Paper Is Cheaper Than Metal
    Hypertherm Powermax 45
    Milwaukee & Hilti Power Tools
    John Deere Equipment
    Paints and Quarterhorses
    Billy Cook Roping Saddle
    Billy Cook Reining Saddle
    Our YouTube Channel
    Nov 2007
    Central Idaho
    203
    Default Alternative to plate
    This is an idea for a welding table that showed up here a few years ago and that I have since built. For the work I do, it is far superior to the previous solid plate table I had because it allows you to clamp pretty much anywhere, is not subject to warping, and works really well for cutting plate.
    Baton Rouge, La
    47
    Quote Originally Posted by mikeswelding View Post
    I like that idea... especially for cutting. I may do mine 1/2 plate and half channel now that I think of it.
