Results 1 to 8 of 8
Thread: steel finishes
    Nov 2010
    25
    Default steel finishes
    hi guys. i have a few ideas on things to make as sculptures. they will be painted on the inside, but grind with a flapper wheel on the outside. how can i keep the metal/steel from rusting from weather? spray can clear laquer? or will that rust over time?
    3,964
    You can spray clear from a rattle can or a spray gun. Or you can have them powdercoated clear. I have used clear polyurathane that i use on my hardwood floor and a spray gun because i has some left over from doing my floors...Bob
    Oct 2009
    306
    I've found that over time the steel tends to rust under the clear. Use stainless?
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    2,958
    fab,
    you'll need to be Surgically Clean when handling the bare metal: Oil from your hands will start the rusting process quite quickly and if you miss the finger prints as well as any dirt/crud you'll end up sealing it and then you'll really notice it.
    Nov 2010
    25
    they are horseshoes, so i cannot use stainless. i guess i could powder coat them....$$$$
    Nov 2010
    25
    i found penetrol....its in the spray can too, just trying to find it.
    Dec 2008
    12
    One of the best ways to treat outdoor sculpture (small scale projects) is by first cleaning it VERY well as SB stated...
    I use Nitrile gloves (not latex and nothing with powder) and wipe down with Acetone as it does not leave a residue behind...
    Then I use a product called "NU-LUSTRE-55" (found at almost any Hardware Store). IT'S Crazy stuff... It will coat ANYTHING as long as it's not 'Waxed or Heavily Polished' and keep it that way FOREVER. Buy the 'Anti-UV' stuff for your application and you're more than good to go. It won't Crack, Peel, or Yellow. Even though it's an 'Epoxy' it can still be brought back to life (should it become seriously scratched or dulled by wind/sand/weather..) by using successive grades of sandpaper. A pumice stone will even bring 'easy access' surfaces to a high gloss after initial sanding...
    Cheers,
    Sep 2007
    Medford MA
    544
    you could also use a hot oil treatment
    brush on boiled linseed oil and heat with a big flame
    like a weed burner. it creates a glazed finish that can
    range in color from a light amber to a deep dark brown
    that is almost black. i think i remember seeng some
    work that was slightly blue or violet too
    there is a giuy on the hobart message board - hotfoot -
    who is a master at it. five minutes with the search tool
    should get you all you need
    post pictures when you are done
    frank
