Just picked up a Millermatic 200. Where the gun cable plugs into the unit there is a (for lack of the actual name) flexible groumet that shrouds the gun cable. Due to age of the unit this groumet has cracked and seperated to where one can actually see the woven wire that wraps the cable. I've been advised to just tape it real good with electric tape and its good to go. Now for the reason for this post - Is it safe to tape it up or should I replace groumet (whatever its called) or the dreaded replace the entire gun cable. The welder works fine. Serial number - JK634850 and I believe the gun to be GA - 20C. thanx
Results 1 to 10 of 10
11-02-2010, 08:05 AM #1
- Nov 2010
- Columbus, Ohio
- 2
Millermatic 200 gun cable flex groumet
11-02-2010, 11:12 AM #2
I assume you're referring to what is called the "strain relief" in the G-20C manual http://www.millerwelds.com/om/o1025d_mil.pdf as item #33. If so and you want to replace it rather than tape it up you can get one here http://miller4less.com/advanced_sear...d5ecaf5cda9872 for $11.35.
However, I suggest buying two as they have a minimum order amount of $20 so you'd wind up paying about the same for one as you would for two anyhow and you could replace both ends. Or figure out if there is any other part(s) you may need/want to add up to at least the minimum order amount.
If you don't have it, you can download the MM200 manual here:
http://www.millerwelds.com/om/o1303m_mil.pdfLast edited by duaneb55; 11-02-2010 at 11:16 AM.
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
11-03-2010, 05:55 AM #3
- Nov 2010
- Columbus, Ohio
- 2
Many thanx for great info
You nailed it. Will order 2. I was somewhat skeptical about taping.
10-10-2012, 12:48 PM #4
- Oct 2012
- 1
I have same problem
Duane55,
Will all the information be accurate for my machine as well? S/N JF918470
I did s/n search and nothing came up. Machine must be to old!Last edited by Darmarhad; 10-10-2012 at 12:56 PM.
10-10-2012, 02:27 PM #5
- Jul 2010
- Four Flags city
- 239
I'm no Duane(by a long shot
) but here are your manuals,
http://www.millerwelds.com/om/o1303p_mil.pdf
10-11-2012, 07:51 AM #6
- Oct 2007
- Cave Creek Az
- 803
I have run those GA-20c gun for a while and finally replaced with a Bernard Q gun and Miller M-25, both are better guns than than the GA-20c. They are both available on ebay for about $100.
10-11-2012, 02:00 PM #7
- Jul 2010
- Four Flags city
- 239
10-11-2012, 02:48 PM #8
I always prefer to replace parts that go out rather than finding a "fix". Fixes are fine if they're safe and I just need to get the job done. But I think the resale value is better down the road with new OEM parts.
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
10-11-2012, 10:19 PM #9
- Oct 2007
- Cave Creek Az
- 803
Both the Bernard Q and teh M-25 are OEM guns.
10-12-2012, 08:05 AM #10
- Jul 2010
- Four Flags city
- 239
The GA-20C was replaced with the M-25 as the OEM gun in 1995.
