Results 1 to 10 of 10
    Nov 2010
    Columbus, Ohio
    Question Millermatic 200 gun cable flex groumet
    Just picked up a Millermatic 200. Where the gun cable plugs into the unit there is a (for lack of the actual name) flexible groumet that shrouds the gun cable. Due to age of the unit this groumet has cracked and seperated to where one can actually see the woven wire that wraps the cable. I've been advised to just tape it real good with electric tape and its good to go. Now for the reason for this post - Is it safe to tape it up or should I replace groumet (whatever its called) or the dreaded replace the entire gun cable. The welder works fine. Serial number - JK634850 and I believe the gun to be GA - 20C. thanx
    Aug 2008
    Orange, TX
    1,052
    I assume you're referring to what is called the "strain relief" in the G-20C manual http://www.millerwelds.com/om/o1025d_mil.pdf as item #33. If so and you want to replace it rather than tape it up you can get one here http://miller4less.com/advanced_sear...d5ecaf5cda9872 for $11.35.
    However, I suggest buying two as they have a minimum order amount of $20 so you'd wind up paying about the same for one as you would for two anyhow and you could replace both ends. Or figure out if there is any other part(s) you may need/want to add up to at least the minimum order amount.
    If you don't have it, you can download the MM200 manual here:
    http://www.millerwelds.com/om/o1303m_mil.pdf
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Nov 2010
    Columbus, Ohio
    Default Many thanx for great info
    You nailed it. Will order 2. I was somewhat skeptical about taping.
    Oct 2012
    Default I have same problem
    Duane55,
    Will all the information be accurate for my machine as well? S/N JF918470
    I did s/n search and nothing came up. Machine must be to old!
    Jul 2010
    Four Flags city
    236
    I'm no Duane(by a long shot) but here are your manuals,
    http://www.millerwelds.com/om/o1303p_mil.pdf
    Cave Creek Az
    796
    I have run those GA-20c gun for a while and finally replaced with a Bernard Q gun and Miller M-25, both are better guns than than the GA-20c. They are both available on ebay for about $100.
    Jul 2010
    Four Flags city
    236
    Quote Originally Posted by walker View Post
    M-25 is a fair gun.....CenterFire ROCKS!
    Jun 2012
    Tracy, CA
    175
    I always prefer to replace parts that go out rather than finding a "fix". Fixes are fine if they're safe and I just need to get the job done. But I think the resale value is better down the road with new OEM parts.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Millermatic® 211 Auto-Set™ w/MVP™
    Spoolmate™ 100 Series
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Cave Creek Az
    796
    Both the Bernard Q and teh M-25 are OEM guns.
    Jul 2010
    Four Flags city
    236
    The GA-20C was replaced with the M-25 as the OEM gun in 1995.
