    3
    Default proper argon flow
    i read in my miller dialarc hf manual that a flow of 15 cf per hour was sufficient but other welders tell me that 25 cf per minute is what they use.
    this is a huge difference in cost to me. any help out there?
    ty
    fuzzy
    Nov 2007
    Ontario, Canada
    72
    15-35 cfh is typical. The actual setting depends on size of cup/tungsten, type of diffuser and whatever just works the best. Not much help, I know.
    XMT-300 with S-64 wire feeder.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter.
    Miller Spoolmatic-1
    Miller PC-300 pulser
    Miller Optima pulser
    Nov 2007
    SouthWest
    More flow is not always better. Start with your lowest setting and check the weld. No drafts around or doors opening either..that will blow / move the gas around.
    Montgomery Mi
    223
    hey fuzzy,
    just checking your post and what i tell the guys at work is if you have your gas flow turned anything above 20-25 your just blowing your gas away from were it needs to be and that is the weld area, if you think about it i know some guys that have it cranked right up to 50-60 and all that is doing is blowing your gas all over the place and not at the weld were it needs to be it is crazy to have to turned up that high i think. but some guys really don't know the importance of gas flow and think if you turn it up the better it is.
    I hope this helps you,
    Dec 2005
    Dallas, TX area
    267
    Default Am I reading this right?
    Quote Originally Posted by fuzzy View Post
    ty
    fuzzy
    25 cf per minute is 100 times the flow rate of 15 cf per hour. Big difference. I am sure they meant cfh. The rule I go by is 14ga and under = 20 cfh. Over 14ga = 25.
    Hope this helps.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    May 2006
    180
    Quote Originally Posted by triggerman View Post
    .....The rule I go by is 14ga and under = 20 cfh. Over 14ga = 25.....
    Unless you (as I do) use a gas lens, in which case you can get by with even less Ar. On light gauge mild steel I use 11 cfh. and my welds look clean.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    New Westminster, B.C. Canada
    8
    I almost always use 20cfh of argon, there's so many variables- cost, work area (drafts), material, gas lens.
    Miller Syncrowave 250
    6000+ hrs Al TIG
    Indiana
    541
    It also depends on who is buying the argon.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Edmonton, Alberta, Canada
    7
    In my opinion anywhere from 15-35 cfh is good. It depends on drafts more or less. If your in a small shop with little draft, no doors opening all the time etc, 15 would be fine. You dont want too much gas flowing as it could cause turbulance and does not provide a good shield around your puddle. Depending on who's paying for the gas is also crutial.... lol
    I would go with 20-25 cfh, it's a safe flow rate.
    I weld...
    Therefore...
    I am....
