Hi all, I just got a new Syncrowave 200 last week and need some help with the set up... I will be using it for mild steel, some SS, and some aluminum. Well lets get down to what I need to start with:
What Number works best when using the Pulse Control?![]()
I weld 1/8, 3/32, 16ga, and 18ga mild steel and SS...
Thread: Syncrowave 200 Help on SET UP
04-22-2006, 09:06 PM #1
- Mar 2006
- 2
04-23-2006, 07:26 AM #2
- Sep 2005
- Lafayette, La
- 319
Congrats on the new 200.
Use 1/16 lanthanated tungsten for 18 ga and below. 3/32 should work from 50A to the top end. You can use it for steel, SS and Al.
Pulser for 16 ga and below (if desired, not really a requirement). Set 100% for peak, 40-50% for background, 1.5PPs to start. Set main amp knob at or a little more than one amp for every 0.001" thickness of material. Use foot pedal for final amp control.
Now...just go play.
04-25-2006, 11:08 PM #3
- Mar 2006
- 2
thanks for the reply
11-17-2006, 09:21 PM #4
- Nov 2006
- 10
This is interesting,
Could you go through the setup steps for the 16ga steel for a total beginner?
I have not even plugged the machine in yet.
Thanks for your help.
SyncroWave 200
