Results 11 to 16 of 16
Thread: PortaBand Stand
    Sep 2009
    South Carolina
    364
    Default Finally got a round to it!
    Found some 1/2" aluminum plate. Used a little preheat for my 200 amp and it went well. The weight was 50lbs and saw, just checking to make sure it wouldn't drop my saw in the floor.
    Also welded a tab towards the back to get the blade more in the center.
    Sep 2010
    22
    Default Portaband stand
    Here is a portaband saw I have converted using things I had around the shop.
    Attachment 26141
    V-Dot Farm
    Millermatic 210 / spoolomatic 3035
    Millermatic 200 / Spoolomatic 1
    Miller 375 spectrum plasma
    Miller Econotig
    Nov 2008
    12
    Quote Originally Posted by Showdog75 View Post
    that thing sweet
    Daye
    Chicago-ish
    282
    Quote Originally Posted by kandrwelding View Post
    I saw a thing-a-ma-bob one time turns your portaban into a little pivoting arm band saw have not found that site again can any of yall help me? I would like to make my own.
    I bought one of these years ago. It is specific to the Porta Band. It uses 3/4" pipe for legs. I don't know who sells them.
    Sep 2010
    22
    Default portaband stand
    I like all the bandsaw designs, but I chose to mount mine using some of the factory bolt holes and that way I could mount my plate with the slit to the front so I don't have to dismantle the bandsaw to change the blade. It is a real practical thing for me because I cut alot of staniless steel so I go thru blades pretty often.
    V-Dot Farm
    Miller Econotig
    Sep 2010
    Terrell, TX
    12
    Default made my own
    I actually made this thinking I was really clever and that nobody had thought of it before, I was wrong
    Laying out the holes, drilling, csk, and cutting the slot for the blade took the longest time. Whole thing took probably 1-1/2 hrs over 2 days to make from scrap. Worked very well for about 2 years, now I'm thinking of ways to "improve" it thanks to you guys.
    BTW I like the one by swag offroad, if I make another I'll probly adapt some of his ideas.
