    Jul 2009
    New York New York
    46
    Default comments and feedback
    Trying to weld a stainless steel exhaust together, prepping the flanges, welds seems to be undercut it but if I set the amp too low it won't even melt the SS .
    any suggestions
    SS flange 304
    SS tube dunno
    filler rod 309L
    solar flux for back
    Dynasty 200DX with argon @ 65 AMP
    any suggestion I can do it better? cause cleaning the molten on back is a pain.
    Mar 2008
    Oklahoma Pilgrim
    24
    More filler.
    Jul 2010
    central Kansas
    66
    More filler for sure and point the to torch towards the undercut and increase heat add filler decrease heat move over 1/8 and repeat the decrease in heat will help the metal cool so it dosent burn thru as easy. you will be layin dimes in no time!!
    Jul 2009
    New York New York
    46
    Thanks will give that a try over the weekend. Welding is not exactly my day job as you can see... Any tips will be helpful
    welding is too not mine job, so i m also waiting for the tips.
