I'm new to tig welding and I'm welding 16 Ga 304 s/s. The bead looks ok but the bead is black not the nice coppery brass colored that I see when other people weld S/S, is it too much heat or not enough or something toatally different. Please help. Thank You.
Thread: Black bead
10-25-2010, 04:52 PM #1
- Dec 2007
- 33
Black bead
10-25-2010, 06:09 PM #2
- Dec 2007
- alabama
- 711
Can be 1 or all of these things: Too hot and/or too slow travel speed; Wrong gas and/or wrong cup angle; Gas lines not sealed,leaking argon or sucking in air.
XMT 350 cc/cv
XMT 350 vs
TRAILBLAZER 302
MILLER DVI
PASSPORT PLUS
DYNASTY 200 DX
MAXSTAR 150 STL
HOBART CHAMP
HF-251 BOX
12-RC SUITCASES
12-VS SUITCASE
10-25-2010, 09:54 PM #3
- Dec 2008
- 12
Crystallization... you're probably cooking it!
Sounds like you're 'too hot' and/or going to slow. Back-purging of some kind will help with both sides of the weld, but is intended for the 'back side'.. (obviously). I've had some success with COPPER behind the S.S. in order to act as a 'heatsink'.
Also, Try again with the tip of your Tungsten 'squared off' just the tiniest bit... Doing this will make the ARC somewhat wider and penetration won't be as 'narrow', thus spreading the heat out a bit more...
Good Luck
10-26-2010, 11:01 PM #4
- Jul 2007
- 241
Im No expert at Stainless,but the only time Ive gotten a black bead is when I put way too much heat into the part.Mike
10-27-2010, 03:59 PM #5
- Aug 2010
- Wisconsin
- 20
It's either too much heat caused by slow speed or welding to hot. It could also be not enough gas coverage. Bottle is low or welding in windy conditions.
