As a side note, DO NOT use brake cleaner to clean anything you weld, it can put off severely toxic gas that can kill you! I havent used a spool gun in years, but yes, welding aluminum in any way shape or form is MUCH more picky of the variables..... Good Luck.
Rudy
Results 11 to 17 of 17
11-07-2010, 12:19 AM #11
T-4 Paraplegic, Runnin' the Pedal With my elbow, now trying to get used to a momentary switch.......
Journeyman Millwright, Local 1102, Detroit, Michigan (Disabled)
Syncrowave 200
Coolmate 1
11-07-2010, 06:20 AM #12
You nailed it! It was actually very windy today. I forgot to mention that. I was trying to weld between big gusts, but that was difficult to do and I could hear the weld sizzle and pop a little when the wind picked up.
Those are great looking welds you did. I really need to get my paws on some thicker material.
11-07-2010, 06:24 AM #13
11-09-2010, 10:22 AM #14
Are you pushing the weld or dragging it?
Kevin Schuh
Service Technician
Miller Electric Mfg. Co.
11-09-2010, 10:41 AM #15
- Apr 2009
- not near you
- 130
11-09-2010, 08:45 PM #16
11-10-2010, 11:41 AM #17
- Nov 2007
- Central Idaho
- 190
Push or pull?
Are you pushing or pulling the weld? With aluminum, a pushing technique puts the shielding gas out in front. Also, as mentioned, try moving faster. I have the PP+ and the Spoolmate 100 and they work great. But yes, it does take practice.
