    Aug 2008
    Thetford VT
    64
    Default Little Repair Job
    Got a call last night to repair this today.Cat 330D excavator bucket broken corner shank. Lots of cutting and arc gouging and a little welding 15 Lbs of 1/16" dual shield.
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    Dec 2008
    Arizona
    812
    Great, I broke one today and will have to fix it tomorrow. The cutting off part really bites!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Lodi, CA
    1,302
    not putting your job down, but I certainly can't see 15 pounds of filler metal there. 5 pounds, maybe. IF that. Been doing this for years, I know. Better check your scales
    Apr 2006
    TAXACHUSSETTS
    1,491
    not putting your job down, but I certainly can't see 15 pounds of filler metal there. 5 pounds, maybe. IF that. Been doing this for years, I wasnow. Better check your scales
    Exactly what i was thinking when reading this thread.Did you fix the broken shank or replace the entire thing?
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Apr 2006
    TAXACHUSSETTS
    1,491
    Quote Originally Posted by nocheepgas View Post
    Try a #4 O/A tip.If you got enough amps like 425-450 a 3/8" carbon arc rod will eat that for breakfast.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
