    Near Lancaste PA.
    3
    Default Alternatives to welding aluminum for puppet stage?
    I just joined this forum because I was looking for alternatives to welding for a puppet stage project I have in mind. I didn't know where else to go.
    I know a shop where the weld aluminum tube on a regular basis. In my case, the heaviest material I will want to use is 1x1 x .060"square tubing (probably .030 wall if I can). But, they say that welding the thin-wall stuff is a problem because the process tends to blast away the base material.
    So, I am looking for alternatives to welding. Here are some options I am considering, but am unsure what will be the best choice;
    - Using flat "L" brackets or triangular gussets and riveting
    those to the frame.
    - Same as above, but epoxying to the frame.
    - Fiberglassing the joint.
    Any comments or other ideas?
    Joe Dunfee
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by cadcoke4 View Post
    those to the frame.
    Joe Dunfee
    Riveting will work and should be pretty cost effective. There is also a transportation grade two part glue or epoxy that I use at work, it would be more than enough in this application. I don't know what the name of it is but I can let you know when I go back to work on Jan 2.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Vancouver BC Canada
    605
    Default sticky situation...
    you could use adhesives.
    try searching out a company called LORD adhesives. they make glues and two parts for everything under the sun and they stick like $hit on a wool blanket.
    http://www.lordfulfillment.com/upload/SG1006.pdf
    http://www.lord.com/Home/ProductsSer...3/Default.aspx
    if you make some corner gussets and use some clamps you could glue your stage together and is would, im sure, hold up very well.
    I wouldnt suggest fiberglass though. its way messier than you want to know. and a pain in the a$$ to deal with.. it stinks, its sticky,frustrating, and expensive..
    as for "blowing out the base metal" that is indicative of skill level..
    A good TIG man shold be able to weld pop cans together on a regular basis...
    ASK ENGLOID on the motorsports side... he is very much experienced.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Near Lancaste PA.
    3
    Thanks for the replies. I think I am going to go with epoxy.
    Joe Dunfee
    it seems strange to join a welding forum to find an alternative to welding. but you could use a low heat soder/weld material. try these guys
    http://www.aladdin3in1.com/
    like said above TIG would be a good choice but MIG may not work out so well on that thin. i would TIG weld it but you could try the stuff aladin has as another option, or go with a 2 part epoxy.
    good luck
