Results 1 to 3 of 3
    Dec 2009
    Bronx, NY
    Default Help: A Question of cutting torches & math . . . :-)
    Hi Folks,
    Just learning and I'm looking for a formula, if there is one for getting a ballpark figure of how much O2 and how much gas to bring to a jobsite for cutting.
    Is there a formula that includes the following factors:
    Thickness of material
    Length of cut
    O2 in cf
    Acetylene in cf
    and assuming the correct tip size (Jeffus, 6th ed. pg 159)
    and median gas flow for that tip size:
    for example: 1" thick material, #2 Smith or Victor tip, O2=35-40(37.5) psi and Fuel@3-5psi (4) what would be the number of inches/feet/meters that could be cut with how many cf of each gas (O2 & fuel) ?
    What I'm really asking is to find a straight forward method of pricing a demo.
    Gas & O2 costs are one factor but the other is knowing how much and what size bottles as well as the amount of hose to haul to the site. My time is the easy part.
    2,641
    Dec 2009
    Bronx, NY
    Default THANKS! for the tipchart...
    BTW there is a problem with HooperSupply.com:
    1...they're using a cut-rate redirection service: Hoopersupply.com may not work in your browser, you need www.hoopersupply.com
    and
    2...the link on their homepage for their tip chart doesn't work. this one does:http://www.hoopersupply.com/tipchart.html
Tags for this Thread
