I can't remember where or when I heard it. But I've always used one and one half times the material thickness for the depth of a hole for pipe or tubing.
So a one and a half schedule forty pipe would be approximately three inches. (1 7/8" X 1.5 would be 2 3/4")
I don't believe I pulled this out of the air. I'm comfortable with saying it's something an engineer or someone close to one told me.
Am I wrong?
10-15-2010, 06:51 AM #1
- Sep 2006
- 273
Drilling depth for posts in concrete
10-16-2010, 07:50 AM #2
- Mar 2006
- northwest Pa
- 76
I belive you are correct, but remember that's minimum.
10-16-2010, 08:52 AM #3
- Sep 2006
- 273
11-10-2010, 08:59 PM #4
A little diffrent but same princable.
I always use 1.5 of the outer dimension for my depth. My experience comes from some college and working as a rigger for some time. My reasoning is this, if you are bolting something up and you only screw in the bolt 1/2 of the OD of the bolt you are not getting max tensile strength of the bolt you must go the OD+1 turn to get max tensile strength out of the bolt. I always shoot for the max, you wouldn’t help pin a weld would you? No you want a full pin. But this is max not min so you make the call on what you need.
