    Oct 2010
    Default Dynasty 200dx basic settings for various metals and thicknesses
    I am looking for a detailed basic chart of settings for the Dynasty 200dx
    More specifically, I am looking for 6 detailed settings for three metals (two thicknesses for each metal); aluminum (1/16" and 1/8"), stainless (1/16" and 1/8") and plain mild steel (1/16" and 1/8").
    I understand there are a lot of variables, however, I feel if I had the above 6 settings, I could get a good start on using this machine.
    I do have the manual that came with the machine, but it does not have the details on the various metals as mentioned above.
    Thank you, Rick
    Are you not using the foot pedal? When I first started out, I would just set the amps high and use the pedal to control my puddle.
    2,634
    Jun 2008
    Mount Clemens,Mi
    350
    I second The Brocc's choice but raise him the calculators and will tell you the best $25.00 you will ever spend is the student package.
    Link to student book package by Miller
    the other best $25.00 you can spend is the Lincoln foundations
    The Procedure handbook of welding, has more infor than most will ever need!
    Plus they are the two best buys in the welding world.
    Procedure Handbook "Fourteenth Edition"
    glen, If your not on the edge, your wasting space
    Jul 2010
    29
    Quote Originally Posted by Slowreaction View Post
    15 years later I still do.
Tags for this Thread
