I inherited an old (probably 1970's vintage) Miller model 250 TIG welder and need to know if there is a way to convert it to a modern type of controller. The fellow I got it from was an electronics genius and designed a foot operated control with a reversible drill and gear reduction box to drive the current setting and trigger the gas, etc. It had a water cooled torch handle that simply dumped into a drain and was regulated by hand.
I want to update it because the old wiring is brittle and the drill needs work. I also want to know if this is worth messing with. It worked great when I used it 20+ years ago.
Any ideas and comments would be appreciated. Thanks.
Results 1 to 4 of 4
12-27-2007, 04:18 PM #1
- Dec 2007
- 3
Oooooold Miller model 250 TIG/ stick welder, need help
12-29-2007, 08:44 PM #2
- Dec 2007
- 3
Anyone have a comment?
12-29-2007, 08:59 PM #3
I would like to help you out, but I don't even know where to begin. Hopefully someone here will be able to help you.
The setup you have sounds neat but really ,um, different.
Good luck.Tim Beeker,
T-N-J Industries
(my side bussiness)
Esab 450i with wire feeder
HH135 mig
Miller aircrafter 330 - sold
Marathon 315mm coldsaw
table saw
Dewalt cut off saw
Sand blast cabinet
lots of hand grinders
Harris torch
beer fridge
12-29-2007, 09:46 PM #4
- Dec 2007
- 3
Thanks. I just came back in from looking at it a little more and doing some more searching here. It appears to be a late 60s model serial # T447724 and the high frequency gear looks to be homemade so maybe I am headed in the right direction. I'm thinking he copied the design of the HF 250-1 unit's internals because it is not a Miller part. One of my main area of desire is to update the drill controlling the current. I saw where there is an accessory control for varying current from the torch handle, fixed mount or foot control. I can post pics if necessary. I am kind of blind on this so thanks for the help.
