Results 1 to 7 of 7
    12
    Default Pipe wraps and templates
    I am going to build some pipe wraps/templates with solidworks in a few days. I will be happy to share the files. You would print them off on heavy paper then use them like a pipe wrap. Or as I am going to do use the prints a templates to cut the wraps out of pipe wrap material. Anyone have suggestions or particular sizes they would like to see. I can do all sizes all angles and any combination of sizes.
    There was a post several months back that offered a program called tubemiter.exe
    I thought I had saved it but today it wont work!! I copied a jepg file.
    Depending on the pipe size, it would draw your template. Maybe a search will locate the program.
    jim
    I found it again!! Saved it too.
    http://www.metalgeek.com/static/cope.pcgi
    jim
    21
    Trap
    you might have been thinking of 'winmiter'
    and here it is
    john
    http://home.tallships.ca/mspencer/winmiter.html
    wow !! we posted at the same time
    12
    Great... Again you guys saved me a bumch of work. Thanks again
    12
    Default One step further
    Great programs. Let's go one more step. For those of us who cut most copes on a chopsaw or bandsaw has anybody seen a program to give us the corrct angle measurements for cutting saddles?
    Jan 2007
    S.W. Missouri
    155
    Here you go. http://snip.awardspace.com/
    This one is on the internet but maybe someone on here can tell us how to download it or put it on a computer so you don't have to be connected to use it.
