Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: line bore job
  1. #31
    Feb 2005
    N.E. SD
    1,381
    Don't forget the trusty scarfing tip
    Jeff
  2. #32
    Jul 2010
    central Kansas
    66
    Default update
    Initial placement of the boring bar with alinement cones.
    Add bearings and support plates.
  3. #33
    Jul 2010
    central Kansas
    66
    Place 24 in feeder
    aline it to the bar
    lock in place
    Hook up hydraulics
  4. #34
    Jul 2010
    central Kansas
    66
    close ups of my homemade feeder
  5. #35
    Jul 2010
    central Kansas
    66
    Default update
    got all set up today just before dark will bore 1st thing in the morning.
    Hope u find it interesting.
  6. #36
    Feb 2005
    N.E. SD
    1,381
    I do like your feed setup. Does the orbit motor have enough power at low speeds?
    Jeff
  7. #37
    Jul 2010
    central Kansas
    66
    Quote Originally Posted by J hall View Post
    O yea there is a lots of torque even at 50 rpm i can snap off a 1/2 tool like nothing. my truck has 26 gpm of flow at base idle so there is plenty of volume at 1800 psi.
  8. #38
    Jan 2009
    Whitehorse, Yukon
    279
    That's a pretty slick low-budget feed unit. I just bought one that's older than dirt. Uses a 3/4" drill to drive it. Gearbox reduction from 1725 rpm to about 200 rpm. The gearbox also drives an automatic feed .008" per rev.
    Works great-- when the drill finally gives up I will replace it with a DC motor and ratiotrol from Boston Gear
    Big Blue 400D
    Trailblazer 302
    Miller S-32 suitcase
    12VS suitcase
    Lincoln LN-7 (BIG suitcase)
    Victor torches
    Lincoln 350MP with 35' push-pull gun
    Lincoln PrecisionTIG 375
    Spectrum 1000 plasma cutter
  9. #39
    Jul 2010
    central Kansas
    66
    That's a pretty slick low-budget feed unitn.
    Thank you
    Well how bout some pics please!!! In use would be even better.
    Works great-- when the drill finally gives up I will replace it with a DC motor and ratiotrol from Boston Gear[/QUOTE]
    gear reduced dc motor is what I started with it worked great but a little low on the torque hard to beat hydralic for power per size. looking forward to the pics.
