Results 11 to 20 of 39
Thread: line bore job
    Jul 2006
    1,508
    I too would like to see pictures. Couple times over the years I've turned cranes over to line bore guys to repair the heel pin holes in the boom. The operation would be done over a weekend, so I never stuck around to see how it was done. Would be very interesting to see, with detailed informations of what is being done!
    Caution!
    These are "my" views based only on “my” experiences in “my” little bitty world.
    Feb 2009
    Lodi, CA
    1,239
    I recall, a few years ago, there was a guy here who did a very professional, home-grown line-bore job. Posted pics on one of these boards, it was JHall if I remember correctly. Center pivot on an articulated Cat loader. Mounted bearings top and bottom, had a 2" boring bar fabbed by a local machine shop, held it up and fed it in with an overhead chain fall, turned it with what looked like a Dodge Screw-Conveyor drive. Could'a been posted on SFT, do a search.
    Feb 2009
    Lodi, CA
    1,239
    Recalling it now, it was either username "JHall" or "Jeff", depending on the forum, do a search monte, this is amazing work, you yourself wouldn't have any concept.
  4. #14
    Apr 2009
    KANSAS
    511
    Quote Originally Posted by dppmfg View Post
    I have an line bore job coming up next week. It will be the first time i have used my set up since converting the thing to hydraulic drive. My new to me truck has auxiliary ports on it.
    The job will not be any thing to major my understanding is that it will be pivot points on some kind of lift.
    I didn't know if you fine folks would be interested in something like that or not.
    If there is interest i will try and take pics and post the job if no one is in to it then i wont wast my time.
    I would ask if you wanted any help but I have to leave monday for Illinois I got your PM but I been to busy to give ya a call. I'll catch up with ya one of these days.
    Take care,
    Tim
    '08 F-350
    Vantage 400
    SA-250
    SA-200
    Invertec V350Pro
    Invertec V205T-AC/DC
    Miller 12VS suitcase
    Miller spectrum 2050
    Pipe beveler's
    Track torch
  5. #15
    Oct 2008
    11
    Default lineboring
    What kind of bar do you use? I use a YORK and really like it,but I love my BORETECH bore welder.
  6. #16
    Aug 2006
    Raymore Missouri
    1,920
    Don't quite get your post....care to elaborate?
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  7. #17
    Jul 2010
    central Kansas
    66
    Quote Originally Posted by junkwelder View Post
    The bar is a home made contraption 1-1/2 bar hyd drive off the truck, hand feed. I am way to poor to afford one of the commercial bars.
    I would love to have a bore welder but just cant justify 7 grand for one I will just keep on welding them by hand.
  8. #18
    Feb 2005
    N.E. SD
    1,377
    Nothing wrong with home made. I'll be looking for your pictures.
    Thanks for the compliments, JS.
    Jeff
  9. #19
    Feb 2009
    Lodi, CA
    1,239
    J Hall, the main reason I wanted to point out your job, seems too many people tend to consider this "over and above" their capabilities. When you cut it down to the basics, line bore is essentially lining up a series of holes. Especially for a "one-off" job, it's not as expensive to do as one would think. One does have to take accurate measurements, and one does have to take their time boring the hole, but in the end it's not rocket science. I always admire the guy, looking around his shop, and figuring he has what's required, with a few hundred dollars more, getting 'er done.
    Last bore job I was involved in, for the price it was beyond my capabilities, reaming out the front steering pivot on a Roadtec RX-45,,,,, 8" cylinder, needed to go down 4 more inches, bored wrong from the factory. I gave the customer the name and phone, guy stopped by in a pickup, took a few measurements,,,, came by a couple days later, with the big truck, everything pre-fabbed, a half-day's work on site, total bill was well below $2000.00
  10. #20
    Jul 2010
    central Kansas
    66
    Default progress update
    machine showed up today. It was a little bit different than i expected. The customer had tried to remove the broken off, rusted in place pin by cutting along the tube with a torch. Not sure why they tried that but guess that is why they build buildings and we fix stuff.
    My plan is to cut out the tube, machine a new one undersized on the id and line bore to size after welding.
    Te pics are not great just snapped a couple before i left the shop
