Results 1 to 3 of 3
Thread: Goat Hay Feeder
    Oct 2010
    Default Goat Hay Feeder
    I decide to build a goat hay feeder for my father in-law by using an old 55-gal barrel and some scrap metal,
    I use the millermatic 211 with .35 flux-core wire,Chop saw and a plasma cutter.
    Raymore Missouri
    1,908
    Looks good. Why not put a top on it? Does it have drain holes?
    What kind of paint? Anything toxic to a goat? They will chew on anything.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Sep 2006
    270
    Looks great.
    You had better be careful with those tools. Before you know it you'll be addicted to making things. Amputation at the neck is the only known cure.....
