Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: did you know?
  1. #21
    ****inson ND
    557
    Talking
    Signwave, that peice is most certainly explosion welded. The tell tale sign is the riple effect in the transition zone. Claded peices of metal are used frequently in the ship building and pressure containment industrys. Explosion welding is generaly done using AN, although other explosive agents such as PETN (most commonly used as the filler in det-cord) or tetrytol (altough rarely, other agents are used). AN is a 90/10% mix of amonium nitrate and fuel oil. They place one peice over the other with a very precise gap and place wooden forms around the top peice. They then place a specific amount of explosive on top of the first peice.
    when they detinate the explosive it slams the 2 peices together at such a high velocity that a jet of plasma forms between the two peices. The plasms burns away any impuritys on the surface of the 2 peices as they join together.
  2. #22
    Scottsdale, AZ
    173
    Quote Originally Posted by Wheelchair View Post
    A few months ago while I was healing from surgery I watched a show about this process( Explosion ** welding on the discovery channel, you may be able to contact them and buy the episode and as I remember the process was very successful.
    Hope this helps
    Wheelchair
    Yea, that was very interesting
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
