Results 11 to 20 of 22
Thread: did you know?
    3,945
    Its called cladding like the nickle and copper in coins. It is done underground outside Pittsburg with explosives. The force of the blast seals the different metals together....Bob
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by shorerider16 View Post
    The shop I used to work at (temp. layoff) had a trailer division. One of the guys I worked with showed me a piece of Aluminum somehow bonded to Steel that acted as a sort of weld in adapter. I'm not really sure how they were joined, but you could clearly see the line of speration between the two metals. I'm going to go out on a limb and say theat the strength of this join was very high as it is used on load bearing transport trailers on public roads.
    I know what your talking about, I was also shown this on a drop deck trailer, didn't believe it until I saw it! I also was shown a coupon of 18ga cold rolled welded to a similar thickness aluminum coupon using a Fronius machine. It's cool to see constant devolopment in this great trade!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    southern B.C
    51
    wow, thanks guy's, does anyone have any sort of references to this stuff???
    I'd really appreciate it
    So. Cal
    335
    Default Try this out..
    I think you might get some more info from here.
    http://www.highenergymetals.com/
    Good luck,
    TacMig
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
    Hampton, Va.
    386
    Smile
    A few months ago while I was healing from surgery I watched a show about this process( Explosion ** welding on the discovery channel, you may be able to contact them and buy the episode and as I remember the process was very successful.
    Hope this helps
    Wheelchair
    southern B.C
    51
    Tackmig and Wheelchair
    thanks very much for all the info
    Nov 2007
    1,270
    Quote Originally Posted by neophyte View Post
    Cold Metal Transfer ?
    Neo
    Here is a link from the Fronius website that explains CMT. Looks like a pretty cool process!
    http://www.fronius.com/cps/rde/xchg/...9_ENG_HTML.htm
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Vancouver BC Canada
    605
    Default here's a piece
    JM,
    Heres a piece of "cladding" as Bob calls it. I have had this piece since i was 12 years old. My grandfather brought it home from a ship yard. It is used to join the steel hull (where strength is needed) to the superstructure (where light wieght is prefered).
    The process as to how its made, i havent the foggiest. So Ill go with Kaboom!!! It sound exciting enough though not the educated answer I would rather have given.
    Enjoy.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    So. Cal
    335
    Default Oh boy here we go..
    Melting steel and fabricating things that were useful was the reason I believe I went into welding. The electrical arc and watching steel melt before my eyes was as good as se%! Now imagine blowing crap up! Oh man, someone please approve this process now.
    TacMig
    We depend On:
    Anderson & Co. LLC
    Metal Cr
    afters
    Scottsdale, AZ
    173
    Quote Originally Posted by Wheelchair View Post
    Hope this helps
    Wheelchair
    I saw that. It has been observed for some time and noted in the military where examples of unlike metal to metal welding takes places in combat situations. Tanks getting hit with with extreme high speed rounds that cause the inside metal to melt and explode in a process called spalling. It was noticed that in testing that welding was taking place. This led to:
    They take to plates that want welded together, lay one atop the other and cover it in plastic explosives. Not sure what kind, but it has to be high speed like det-cord.
    In spite of it sounding crude it is far from it. It is a very precise process. Too much C4 and the metal no longer is with us, too little and nothing happens.
    here is some more info:
    http://www.metalwebnews.com/howto/ex...e-welding.html
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
