Results 1 to 3 of 3
    Nov 2007
    19
    Default lincoln weldpak hd wire ?
    i got a lincoln weldpak hd fluxcore wire welder. i was wondering if a 10lb spool of wire will fit in it. it seems like im always using these one pound spools up soo fast. will a 10lb spool fit? THanks
    Oct 2007
    West GA
    71
    Default weldpak
    I have a weldpak 100 and the 10lb spool will fit in it with the the right parts and I get all of mine at home depot along with the big spool and it was the best price that I could find to.
    McDonough, Ga
    9
    Default 10 lb spool
    I have a Lincoln Hd and use the 10 lb spool just fine. Hope you have the adapter that came with the machine.
    Kubota8540
