Results 1 to 3 of 3
Thread: miller 150 mig
    Sep 2010
    Exclamation miller 150 mig
    I have a miller 150 and I need to use it in 4 to weld sheet metal.Any body knous the heat is so low in 4,Tnaks
    Raymore Missouri
    1,922
    don't understand the question
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Mar 2010
    Ceres, California
    358
    Default mm150
    4 is the highest setting. should put out around 120 amps.
    If 4 is not hot enough to weld sheet metal 16 gauge or less
    your welder has a problem. you should be able to weld 1/4 inch in 4. with 0.035 wire.
    You will need to check your miggun and make sure the weld conductor is no open.
    Then check your work clamp and cable. Some times the wire breaks inside the insulation. After that it is inside the welder to find loose connections, bad diodes and weld contactor. unplug welder before removing the case or get help.
    Please down load Mozilla firefox and use it as your browser. It has spell check that works with this site and you can correct your spelling before posting.
    Glenn 300 amp stick
    Millermatic 35
    L-tec plasma
