Results 1 to 2 of 2
    May 2007
    20
    Default Lincoln Handymig 100 question?
    Hey guys, i have a backup welder apart from my 210. Its for when i just wanna flux weld something and dont wanna set up the bigger one.
    My question is that the wire is always hot. I heard from some people that this is normal on this model of welder. When i push the trigger, the wire comes out perfectly. Its kinda a pain in the ***, cause i am so used to the wire only being hot when the trigger is pushed.
    If anyone else can enlighten me thanks, as i don't wanna fix something that isn't broken.
    Indiana
    541
    I had from, a deal, a little 90amp century. The wire was always hot. I did not like it. The welder was to small anyway so I sold it. I got 100 bucks for it, way more then it was worth. I think the always hot wire is normal for the lower amp (cheap) machines.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
