Results 11 to 20 of 36
    Nov 2005
    22
    Quote Originally Posted by arrowside View Post
    What's your balance set at? Is your CFM/ gas flow set correctly? I'm not familiar with the 200, but does it have a %HF setting?
    I can't change my balance in DC. 13CFH. No, I can't adjust the HF.
    Vancouver BC Canada
    605
    Default say cheeze!!
    take another pic Toofazt. lets have a look
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Nov 2005
    22
    Quote Originally Posted by SignWave View Post
    You asked for them... I know the welds suck, but that's not the point
    It seems like I get the black soot when I slow down. You can see the differences in the pictures below. All welded one after another, just different speeds... I've also been able to keep a clean pointed tip on the tungsten so far Maybe I just need to speed up my welds?
    150A, 10PPS.
    Nov 2005
    22
    Nov 2005
    22
    Ok, I have no idea what is causing the black soot now. I just went out and welded a bead quicker than I was before and it just gave me lots of the black soot and pin holes
    May 2007
    Apache junction, AZ
    16
    its the mil scale. trust me. grind it off so there is none closer than 1/2" to your weld. it should come out looking nicer and no black soot.
    Nov 2005
    22
    Quote Originally Posted by Canada View Post
    Really? I sand blasted it about 1" from the edge of each piece. I'll clean it better and try again... Thanks for the suggestion
    ****inson ND
    557
    Talking
    Theres your problem. Don't sand blast it. Blasting inbeds oxides and blasting media into the metal contaminating the welds. Since there arn't realy any scavenging agents alloyed into most Tig rods there can't be any contaminanints in the weld zone. We had the same problem at the last company I worked at. I kept telling them to stop blasting everything but they never listened. 45% of production time was spent making repairs.
    Jul 2007
    Lancaster, Pa
    431
    Quote Originally Posted by Anti-GMAW View Post
    I think this happens in all places of business, where the less informed or less educated fail to listen to somebody more knowledgable. My favorite saying at work for this is " Never enough time or money to do it right but always enough time and money to do it over "
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Nov 2005
    22
    Good to know! So the only way I should prep the surface is with acetone and a stainless wire brush? Or grinder? Thanks again, sorry for the newbie questions
