Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
    Nov 2005
    22
    Default Tungsten help...
    What would cause my electrode to melt into this shape after about 6" of welding? It's 2% thoriated tungsten ground to a point DC welding 3/16" steel 150A. I was playing with the pulsing from 2-10pps. I found a chart and the closest thing I could compare it to was touching the filler metal to the tungsten, although I'm 99% sure I didn't...? Done on a Syncrowave 200. Any help would be appreciated
    This was the second time around after about 6" of welding:
    Nov 2006
    Lake of the Ozarks MO
    3,593
    Trust me ....you did
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Nov 2005
    22
    lol, ok. Does it look like the second one was touched also?
    Aug 2006
    near rochester NY
    9,881
    Question
    are you electrode + or - ???
    Nov 2005
    22
    Quote Originally Posted by fun4now View Post
    Negative....
    Aug 2007
    Vancouver BC Canada
    605
    Default look for soot
    Is there any soot around your weld bead? if so you did touch.
    Maybe you did what i did today....
    I have the simliar result and for the life of me i couldnt figure out what was going on...
    my tung was all black and sugary and the alumiunm wouldnt weld.... Sigh.. I tried increasing the amps and lowering them... sigh nothing seemd to work to get that darn elecrode to stay clean. I had to repoint six times!!! sigh.
    then it dawned on me... (yeah slow thinker) I said to my self last night before i quit for the eve, dont forget that the machine is in DCEN.. youl have to swith back over in the morning cuz welding stainless is different from ALuminm...
    My problem today was that i was trying to weld aluminum with a stainless filler rod ..... sigh.. how's that for smart?
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Nov 2005
    22
    Yes, there was a little soot around the weld bead. I was using the correct filler rod because it's the only kind I have right now
    Nov 2007
    Ontario, Canada
    72
    Quote Originally Posted by SignWave View Post
    Could be worse, signwave, my machine does mig/tig/stick and 'cause I don't weld very often, I have to get the manual out.
    XMT-300 with S-64 wire feeder.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter.
    Miller Spoolmatic-1
    Miller PC-300 pulser
    Miller Optima pulser
    Nov 2005
    22
    Ok, I've got it down enough to not contaminate the tungsten. But now after a couple of welds, I'm getting a black soot around the weld... What's that from?
    What's your balance set at? Is your CFM/ gas flow set correctly? I'm not familiar with the 200, but does it have a %HF setting?
    "smokin' joints for 19 yrs."
    A.A.S. Weld Tech.
    AWS CWI 08011711
