Results 11 to 12 of 12
    Nov 2010
    Michigan
    34
    thanks for that great bit of info
    I have some 3/16 aluminum diamond plate to cut .. i will give it a try .
    wish i had known about it while doing this build
    http://www.millerwelds.com/resources...-Aluminum-pics
    Don
    Sep 2006
    316
    Make sure you use a blade for aluminum. The Steel Demon will gaul up and you'll be using bad words with my name in between them. Don't want that.
    H.D. doggone their hide, carry a blade just for cutting aluminum.
