Results 1 to 3 of 3
    Mar 2010
    Ontario
    157
    Default Building a Utility Trailer
    I am building a trailer to haul around my two atv's and mabye some wood or just about anything that you would use a trailer for.
    I am using 2x2 tube .125 wall and 2x2x1/4 angle all for the bed frame it is 7 feet wide and 12 feet long. With the torsion axle's I am using they are stubs so I had to put double frame rails down each side and the crossers are at 20 inch centers.
    I will be using 1x1 x.125 for all the upper frame sides covered in 3/4 expanded metal
    and the two drop gates for loading will also be 1x1 tube.
    the axles are 3500# with 15 inch tires.
    Question----- Do you think this will be to heavy? I wanted to make it strong and sturdy able to handle alot.
    And also a plant shut down that I did work at so I got a super deal on alot of steel
    tube,angle,flat bar pipe and so on and that is what i had to work with!!
    I will post progression pics to see what you all think
    Also I do alot of mobile repair but this is my first trailer build project
    Lake of the Ozarks MO
    3,593
    There is no way that is too heavy. Not IMO
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Warren PA
    103
    the weight should be easily calculated. You should be able to find charts on weights of various shapes on steel supplier web sites.
    For example, the 2x2x1/4" angle weighs 3.19 lbs/ft, the tube weighs 3.05 lbs/ft.
