Results 1 to 6 of 6
    Default Rebar on a Bar B Q Grill ??
    Anyone ever use rebar on a grill? We have a lot of 1/2" & 5/8" and two 30" fire pits. I don't know if the rebar will sag when it gets hot??
    jim
    Oct 2005
    Bulverde, Tx
    1,244
    Rebar works great for grills. It will sag, so just put a couple of cross pieces under the grill surface. My dad has a grill made of 1/2" that is 3' long and 2' wide. It has two cross bars and not a single bar has done any sagging.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Valemount B.C. Canada
    7
    Does the beef stick to bumps on the bar, any time i've heated rebar to bend it, it gets all flakey, is this a problem.
    Dec 2006
    Wartburg,Tn
    575
    or you could use 1/2 round soild stock or 3/8 or whatever size wanted
    Inferno Forge
    Chris
    southern B.C
    51
    Default rebar
    no reason it won't work. i've done the same thing
    Scottsdale, AZ
    173
    No, I think I would pass on this. It has been tried by many cities and states and it has some disadvantages. It does sag and overall does not hold up to heat real well, especially so if you are doing some large cooking.
    It does flake a bit, but does put some iron in your blood.
    It will also burn out fairly fast if used often.
    That said, if its a small BBQ and you are just going to throw on a few burgers from time to time go ahead and use it. But if you live down south, like where I come from (Texas) where we BBQ just about year round, you will not find many folks using it and no one using it again.
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
