Results 1 to 3 of 3
    Nov 2006
    407
    Default bending S.S. rod with heat ?
    guys,
    is it ok to use oxy-acetylene to heat up 1/2" thick S.S. 316 rod and bend it 90* ?
    i have done this with steel rod before, but never stainless steel.
    thanks
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    Apr 2010
    278
    Sure, unless it needs to be used in some highly corrosive environment. It could be a little better if you heat, bend, reheat and quench it quickly. What you making?
    Nov 2006
    407
    Quote Originally Posted by USMCPOP View Post
    thanks for the help... not sure where its going, but some sort of bracket type thing.... boss ran it by me before i left work today....
    im assuming the discolored area, from the heat, will polish/buff out ?
    SyncrowaveŽ 200
