Results 1 to 3 of 3
    Dec 2008
    Omaha, Nebraska USA
    44
    Default Torch Cart w/ Hose Real
    Here is a quick project I put together with left over steel from projects. The hose real was free I put new O rings in the spin coupler. It had a slight leak. All that need to be finished is the hold down for the tanks. When I pull the hose out the cart does not move. Itís going to be nice not to fight hose any more.
    Jun 2007
    16
    Nice. Gives me some answers/ideas regarding my cart. Thanks.
    Thanks,
    Evansville, IN
    2,348
    With the tanks offset to one side doesn't it push or pull a bit oddly? I have had loads on a 2 wheel dolly and if the load was offset it was hard moving it. Just curious, Thanks
