    116
    Default Utility trailer 89% done.
    Well there are hundreds of welds and cuts in this project. Even though I am missing some hardware I have started painting it. I will be finishing it at another location, so the paint needed to go on now.
    The gates all four of them, well some of you might think stupid but for my needs they are perfect, the small one at the front will help me when loading my bike on it.
    Anyhow I wanted my own design ideas and got them into this project.
    WY...armpit of U.S.A.
    659
    With just the two perimeter angle sections from the end of your hitch mount to the front of your axle you look to be lightly framed.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    116
    Hello Roy, I am not quite sure what you are meaning. I got a trailer company to make the frame for me, with the axle wheels and towing hitch. I then built it frame up. Are you meaning that it is weak at the towning end and if so what should I do. This is my first real project it could be said, so any pointers will be very welcome.
    The company charged me less than I could purchase the stuff to do it with, if I had bought them myself.
    Cheers,
    James.
    Nov 2008
    Colorado Springs
    276
    What is the tongue made from?
    Channel or angle
    as far as the frame is concerned, it looks way light but I think your top end will give you enough strength for a 3500lb trailer. Just don't remove the top bars over the side doors, it might fold.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    Nov 2008
    Colorado Springs
    276
    Oh!
    forgot to say it does look nice though
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    and other fun toys
