Good afternoon all,
I'm pleased to become a participant (and newest member) in this forum. I'm not an expert welder but am gaining experience and really enjoy the time I spend working on projects. I have two MIG welders, one "stick" welder, an oxy/acetylene welder and a "plastic welder.
I've retired from the phone company after more than 30 years. I have a degree in Civil Engineering and do all my own work on our vehicles, house, tractors, fences and what'all.
I look forward to reading, learning and maybe even one day, helping someone in return for all I hope to be gaining from this group.
Regards,
Kubota8540
Results 1 to 10 of 12
Thread: Kubota8540
12-17-2007, 03:18 PM #1
- Dec 2007
- McDonough, Ga
- 9
Kubota8540
12-17-2007, 03:36 PM #2
tell me (us) about your plastic welder Kubota. I have a m/c fairing in need of some lovin and ive been thinking about adding a setup to the shop. Never hurts to increase your ability base.
Thanks in advance and welcome aboard!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
12-17-2007, 04:33 PM #3
- Dec 2007
- McDonough, Ga
- 9
Plastic Welder
dHi Signwave,
The Plastic Welder is called a "ThermoPlastic Welder" and is made by Pamran Elec. Co in New Jersey. It welds ABS,PVC, PE,PP and TPUP. The inital cost for the starter kit is around $180.00.
I'ts essentially a heat gun with a smaller nozzle, filler feeder and whatever other accessories you desire. I installed a PVC fence around our pasture for the horses and used it to weld the joints on the gates I made. So far they've held up well.
After you "weld", you have to let it sit for 24 hours before putting maximum stress on the joint. If I use the word "vulcanizing" as it refers to rubber, this is doing the same thing only to the plastic.
Here is their website if you're interested: www.pamran.com/
Regards,
Kubota8540
12-17-2007, 06:28 PM #4
Thanks Kubota. Im gonna get me one of those! For some reason i thought they were more expensive than that. Musta been the guy at the motorcycle shop trying to protect his income...
Syncro200
Spectrum 625
O/A
54" laminator
little dog
12-17-2007, 07:14 PM #5
That plastic welding does look interesting. The only trouble I see is keeping the base plastic and the rod at the right temperatures so you get an even melting process for a smooth finish. I imagine its a lot harder than they say on the web site, at least until you catch onto it.
Would be a good side to get into though, not many plastic welders around. Like I read in another post, we are getting into a throw away world and buying new. Right now the economy is slow, money is tight, repair the product at half the cost of a new one.Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
12-17-2007, 07:41 PM #6
- Dec 2007
- McDonough, Ga
- 9
Kubota8540
Ken,
You're correct, it's not as easy as one might think. The base material has to actually draw the fill material into it. Keeping the base at the correct temperature without "puddling" is a challenge.
The "High Speed Tip" is a must if you do extensive joints as I did on the gates. It's also expensive for the little thing you get. I also noticed that the welder has increased 33% since I bought mine.
The only other thing to be careful of is to match the filler with the base. There are 5 types of filler rods to match the material being repaired.
12-17-2007, 08:33 PM #7
Hmmm sounds a bit like working aluminum.
There is a distributor in vancouver called GE polymer shapes. Or ther used to be. I think they just sold out to some other comapny, but anyway, these guys carry all kinds of plastic shapes and sizes. lots of different grades and types of plastic too.Will it weld? I loooove electricity!
Syncro200
Spectrum 625
O/A
54" laminator
little dog
12-18-2007, 08:59 PM #8
- Jun 2006
- Killingworth,Ct.
- 372
Kubota
Wow, first ive seeen on here,Ive been welding Koraseal for 25+ years,,Its a flexable pvc,thats used in the chrome plating industrie,,Ive been using a Kam weld welder,same thing electric,and air,approx 4 pounds,I run a 950 degree heating element,,also have done alot of Poly pro,pvc,all for tanks,,,Nice to see another plastic welder,Jack
12-19-2007, 06:31 AM #9
Thats cool never done that "plastic welding". Is there a way to tell which plastic your repairing besides getting info from manufactor? Any character or obvious differences in them
Scott
HMW [Heavy Metal welding]
12-19-2007, 08:27 AM #10
good to have you with us.
james@newyorkmetalart.com
