Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: tig help
    Jul 2010
    12
    Default tig help
    I have been learning to tig on both steel and aluminum. My aluminum welds are looking very good, my problem is with steel. The welds are a dull gray color and porous. I am using a 180sd, thoriated, and the steel was ground and cleaned. I am practicing on 3/16" plate.
    Nov 2008
    Colorado Springs
    276
    Tell us more. Amps, gas flow, etc.
    Then we can help
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    Jul 2010
    12
    I have tried many different amp settings from too hot to too cold and the result is the same. The gas flow is about 15. The gas flow is the same as I use when doing the aluminum. The rod is ER70S2. Thank you
    Oct 2009
    Reno, NV
    299
    Are you welding in the same conditions when using either steel or aluminum? The same joint in the same position? No wind or fan blowing on the work when doing the TIG on the steel? Also, aluminum and steel should usually be done with different gasses..... Remembering to switch to DC when doing steel from the AC used for aluminum? Just thought I would throw those out there in case......
    Don J
    Reno, NV
    Jul 2010
    385
    Quote Originally Posted by dondlhmn View Post
    Really? I thought straight argon was good for both.
    Jul 2010
    12
    I am using ac for aluminum and dcen for steel. Same gas for both, 100% argon, same flow. Like I said my aluminum welds are looking very good but the steel is not. No joints just practicing on flat material. Same conditions, welding inside garage no wind. I was thinking maybe not enough gas flow, but if that was the case, wouldnt that effect the aluminum more?
    Oct 2009
    Reno, NV
    299
    Talking
    Quote Originally Posted by Helios View Post
    I didn't say that some people DON'T use the same gas. I said that USUALLY folks use different gases for different metals (ESPECIALLY true for MIG) because they don't want to waste money and they want to get the best possible result when they weld. Some guys always want to argue about anything they can, but it doesn't mean they are always (or even sometimes) right.
    If you think otherwise, have a look at the guidelines for gas use that Miller publishes for TIG. If that doesn't do it, try looking at the webistes for various gas providers. Maybe even do further research and/or reading in other publications.
    Don J
    Reno, NV
    Lodi, CA
    1,313
    Try using a gas lens for your steel and SS, you will be amazed at the difference.
    Lodi, CA
    1,313
    I didn't say that some people DON'T use the same gas. I said that USUALLY folks use different gases for different metals (also true for MIG) because they don't want to waste money and they want to get the best possible result when they weld. Some guys always want to argue about anything they can, but it doesn't mean they are always (or even sometimes) right.
    ALL tig must be done with inert gases, which means either argon or helium. NO CO2, or O2 can be in the mix. Different from mig, where you usually need a little reactive gas in the mix for steel and SS.
    Mar 2010
    245
    you need to use the force luke, become one with the puddle, be the puddle, Nana nana nanananaanananaaaa
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
