Results 11 to 16 of 16
    Jun 2008
    Mount Clemens,Mi
    350
    And just a reminder, that all hole saws have different mounting systems. I must have 6 different brands due to not being able to get the proper size when needed. So if its not the brand you own buy a mandrel while getting the saw part. The Lenox brand are bad right out of the package.
    glen, If your not on the edge, your wasting space
    Aug 2010
    Wisconsin
    20
    Have you considered a slugger bit?
    May 2005
    NYC
    23
    I am a fan of holesaws but these come in handy as well:
    http://www.harborfreight.com/knockou...kit-91201.html
    I also love step bits.
    http://www.amazon.com/Neiko-Titanium.../dp/B000FZ2UOY
    Import FanatiX Car Club (My Family) www.ifxcc.com
    MM135
    MM350P
    DYN200DX
    Big Window Black
    Contractor Kit
    Lots of questions.............................
    Jul 2010
    central Kansas
    66
    what equipment do you have drill press, mill, lathe, mag drill??
    File Rock.
    I would set it in my fadal mill program and let it rip
    In the field i would clamp it in my vice on the back of my truck.
    set up my mag drill rough it with a 3/4 em then finish it with a 1/2 in boring bar mounted in a boring head and finish.
    Good luck
    Ocean City, Maryland
    951
    I dont know about all your hole saws, but i have several brands too. And none of them cut that great a hole. Funny, they all seem to "wobble" some. Good at cutting a rough hole but not if has to be perfect. But i'd beat on a go cart frame, its probably good, or do like someone else said and cut a smaller hole and file away..
    Scott
    HMW [Heavy Metal welding]
    Oct 2010
    Zip code 71110
    10
    Unless I send the pieces to an actual machine shop to be chucked up on a mill, it doesn't get much more accurate than this for me: http://www.hougen.com/
