Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Jan 2007
    Rosetown, SK.
    519
    Progress looks good,keep up the good work.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
  2. #22
    Mar 2007
    Deltaville, VA
    2,239
    Showdog,
    That's definitely not a "hack job".
    Looks like a job done well. Not picking up a piece of aluminum plate and welding it on.
    I don't do a whole lot of skeg replacements here on the Cheasapeake (not many rocks) but when I do, they normally run about $250-300. I never "get in a hurry" because I'm always concerned about overheating the seals in the lower unit.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
  3. #23
    Nov 2006
    Lake of the Ozarks MO
    3,538
    Using a mig for that is definitely getting "in a hurry".....once I was replacing a skeg on a 125HP Force and used the spoolgun that day. It had enough energy to cause the "bullet" to go out of round temporarily It was popping and creaking and even seeped out grease.
    It was a rush job for a side job a friend at a marina was doing. I called him at the first sign of trouble. He was on the phone with me as it cooled and everything was fine. It's been going for a couple of years now. That is about as close as you come to a MAJOR screwup.
    I prefer to leave the grease in the unit and have everything all torqued in place so when everything cools it comes back to the shape it needs to be. An empty case can warp. That said I fix a lot of those also.
    No matter how you go about fixing these you shouldn't just jump on it and weld like crazy. It could bite you. You can use a mig but you need to skip around and take a break or two so the heat can absorb into the entire unit.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
  4. #24
    CT.
    333
    Nice job. Now that's taking pride in your work.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
  5. #25
    Jul 2008
    East Tennessee
    614
    Here is a couple of shots of the repair complete.
    Dynasty 200DX "Blue Lightning"
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Fixer upper 1968 Redface Lincoln sa200
    Powcon 300st
  6. #26
    Very nice job........
  7. #27
    Oct 2008
    Louisiana
    77
    Post
    Man that looks excellent ! Keep up the good work.
    Miller Dialarc 250
    Miller Spectrum 625 X-treme
    Miller Bobcat 225
  8. #28
    Jun 2009
    Las Vegas Nevada
    132
    when I started reading this thread I didn't know what a Skeg was.
    Is there really a Skeg Depot or is that a coastal joke....
    Steve in the Mojave desert
    Miller Diversion 165
    1966 Bridgeport Mill
    Leblond 15x 35 Regal Servoshift lathe
    Solberga SE 1425 Drill Press
    Bigass Bandsaw
    Hydraulic press
    small surface grinder
    Belt sander
    Tons of grinders and hand tools
    Knife edge Balancing rollers
    Heat and AC in the garage
    Jags and racing Triumphs
  9. #29
    Nov 2006
    3,538
    Hey Showdog, great job!!!
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
  10. #30
    Nov 2006
    3,538
    I thought I'd bump this old thread just for the heck of it.
    BTW Showdog....did you ever weld/fill that hole?
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
